Mobile App Not Working (Problem with console_config.json)
The mobile application cannot get a response from https://xxx22.online/api/master/apps/consoleConfig, it returns a 500 error.
Request failed with HTTP error status: 500 Internal Server Error
Please contact the help desk.
Error in the logs:
INFO    [WebService task-2             ] r.e.container.web.WebServiceExceptions : Web service exception in 'RESTEasy Dispatch' for 'GET http://xxx22.online/api/apps/consoleConfig', root cause: java.lang.NullPointerException: Cannot invoke "java.nio.file.Path.getFileSystem()" because "path" is null
The file console_config.json is located at /deployment/manager/app.
Here are the contents of the console_config.json and docker-compose.yml files:
console_config.json:
  "showAppTextInput": false,
  "showRealmTextInput": false,
  "app": null,
  "allowedApps": ["manager"],
  "apps": null
Docker-compose.yml:
  proxy-data:
  manager-data:
  postgresql-data:
services:
  proxy:
    restart: always
    depends_on:
      manager:
        condition: service_healthy
    ports:
      - "80:80" # Needed for SSL generation using letsencrypt
      - "${OR_SSL_PORT:-443}:443"
      - "8883:8883"
      - "127.0.0.1:8404:8404" # Localhost metrics access
      - proxy-data:/deployment
      TZ: ${TZ}
      LE_EMAIL: ${OR_EMAIL_ADMIN:-}
      # Let's Encrypt
      OR_ACME_ENABLED: "false"
      OR_ACME_EMAIL: "xxx22@list.ru"
      HAPROXY_CONFIG: '/deployment/haproxy.cfg'
      PROXY_LOGLEVEL: "debug"
  postgresql:
    restart: always
    shm_size: 128mb
      - manager-data:/storage
      TZ: ${TZ}
  keycloak:
    restart: always
    depends_on:
      postgresql:
      - ./deployment:/deployment
      KC_HOSTNAME: ${OR_HOSTNAME}
      TZ: ${TZ}
  manager:
    privileged: true
    restart: always
    depends_on:
      keycloak:
    ports:
      - "127.0.0.1:8405:8405" # Localhost metrics access
      TZ: ${TZ}
      OR_SETUP_TYPE:
      OR_ADMIN_PASSWORD:
      OR_SETUP_RUN_ON_RESTART:
      OR_EMAIL_HOST:
      OR_EMAIL_USER:
      OR_EMAIL_PASSWORD:
      OR_EMAIL_X_HEADERS:
      OR_EMAIL_FROM:
      OR_EMAIL_ADMIN:
      OR_ADDITIONAL_HOSTNAMES: ${OR_ADDITIONAL_HOSTNAMES}
      OR_FORECAST_SOLAR_API_KEY:
      OR_OPEN_WEATHER_API_APP_ID:
.env:
TZ= America/Denver
OR_HOSTNAME=xxx22.online
MAP_TILES_PATH=./deployment/map/mapdatanew.mbtiles
MAP_SETTINGS_PATH=./deployment/map/mapsettings.json
KC_HOSTNAME=xxx22.online
KC_HOSTNAME_ADMIN=xxx22.online
OR_ADDITIONAL_HOSTNAMES=www.xxx.online
OR_ADMIN_PASSWORD=secret
OR_EMAIL_ADMIN=admin@xxx.online
Sorry for the late reply.
This is under investigation and should be fixed in the next release.
See GET apps/consoleConfig returns 500 error · Issue #2440 · openremote/openremote · GitHub
