My question is simple, but I’m not able to move forward, so I came to ask for some help.
Through HTTP I can update an attribute of an asset through this endpoint:
- http://localhost/api/{{realm}}/asset/{{assetId}}
with a payload similar to this:
"ref": {
"id": "BCkOADICFykhLh8EFhMKAz",
"name": "notes"
"value": "HTTP method update"
I would like something similar for MQTT, which describes in the payload which asset and attribute I want to change (as they are different attributes)
I took a look at these documentations:
This seems to be the solution I’m looking for, but I can’t find the JSON structure. I’m always getting this exception:
com.fasterxml.jackson.databind.exc.InvalidTypeIdException: Could not resolve subtype of [simple type, class org.openremote.model.attribute.AttributeEvent]: missing type id property 'eventType'
at [Source: (String)"{
"ID": "BCkOADICFykhLh8EFhMKAz",
"name": "KModel_F_WI",
"attribute": {
"name": "notes",
"value":"Next Try"
}"; line: 8, column: 1]
I’m currently trying to send my payload to this topic:
/{{realm}}/{{clientId}}/writeattribute
These were the payloads I tried:
"name": "Name_Asset",
"attribute": {
"name": "notes",
"value":"Next Try"
"ref": {
"name": "notes"
"value": "Next Try"
"type": "ThingAsset",
"attributes": {
"notes": {
"type": "text",
"value": "Next Try",
"name": "notes"
I would like to know what exactly is the structure needed to work with the AttributeEvent, what should I send in the payload?
Any help would be appreciated, thanks.
