Hi.
I need help in the proper setting. I need to get all the current values: voltage in V, current in A, present power in W and total power consumption in kWh.
Included in the Z-Wave network a new Node - power meter AeonLabs HEM1-100A.
<?xml version="1.0" encoding="UTF-8"?>AEON Labs
BASIC_TYPE_ROUTING_SLAVE
GENERIC_TYPE_METER
SPECIFIC_TYPE_SIMPLE_METER
true
true
ELECTRIC_METER
ELECTRIC_METER_SCALE_W
ELECTRIC_METER_SCALE_V
ELECTRIC_METER_SCALE_A
ELECTRIC_METER_SCALE_KWH
true
I created in the the Designer appropriate commands and sensors. In the configuration added the following commands:
3
1
1
4
1
2
5
1
2
If I create a sensor “value”, I get:
Voltage, V 100
Ampere, A = current
Power W = 100
Power kW/h = increases.
But if I create sensors “custom”, I get the correct values:
Voltage, V 220
Ampere, A = current
Power W = real power load
What type of sensor to use?
How to get the current values for all sensors (voltage, current, power)? Now just get the current (A) and power kWh.
log:
DEBUG 2016-10-10 16:25:39,029 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:25:39,029 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x97, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x8B]
DEBUG 2016-10-10 16:25:39,030 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x97, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x8B] has been received.
DEBUG 2016-10-10 16:25:39,031 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0x97, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:25:39,032 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.943’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:25:44,030 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:25:44,030 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA3, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xBF]
DEBUG 2016-10-10 16:25:44,031 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA3, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xBF] has been received.
DEBUG 2016-10-10 16:25:44,032 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA3, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:25:44,033 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.955’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:25:49,030 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:25:49,030 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9D, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x81]
DEBUG 2016-10-10 16:25:49,031 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9D, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x81] has been received.
DEBUG 2016-10-10 16:25:49,032 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9D, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:25:49,032 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.949’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:25:54,030 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:25:54,030 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA5, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xB9]
DEBUG 2016-10-10 16:25:54,031 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA5, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xB9] has been received.
DEBUG 2016-10-10 16:25:54,032 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA5, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:25:54,033 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.957’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:25:59,032 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:25:59,032 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xB4]
DEBUG 2016-10-10 16:25:59,033 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xB4] has been received.
DEBUG 2016-10-10 16:25:59,034 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:25:59,034 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.96’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:26:04,033 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:26:04,033 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x8C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x90]
DEBUG 2016-10-10 16:26:04,034 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x8C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x90] has been received.
DEBUG 2016-10-10 16:26:04,035 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0x8C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:26:04,036 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.932’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:26:09,033 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:26:09,033 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x92, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x8E]
DEBUG 2016-10-10 16:26:09,034 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x92, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x8E] has been received.
DEBUG 2016-10-10 16:26:09,035 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0x92, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:26:09,036 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.938’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:26:14,033 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:26:14,034 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xAB, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xB7]
DEBUG 2016-10-10 16:26:14,034 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xAB, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xB7] has been received.
DEBUG 2016-10-10 16:26:14,035 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0xAB, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:26:14,036 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.963’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:26:14,108 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:26:14,109 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0x21, 0x64, 0x00, 0x00, 0x09, 0x56, 0x00, 0x78, 0x00, 0x00, 0x09, 0x4E, 0xF3]
DEBUG 2016-10-10 16:26:14,109 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0x21, 0x64, 0x00, 0x00, 0x09, 0x56, 0x00, 0x78, 0x00, 0x00, 0x09, 0x4E, 0xF3] has been received.
DEBUG 2016-10-10 16:26:14,110 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0x21, 0x64, 0x00, 0x00, 0x09, 0x56, 0x00, 0x78, 0x00, 0x00, 0x09, 0x4E]]
DEBUG 2016-10-10 16:26:14,111 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_KWH’, Value=‘2.39’, PreviousValue=‘2.382’, Delta=‘120’, RateType=‘Import’].
DEBUG 2016-10-10 16:26:19,034 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:26:19,034 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x91, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x8D]
DEBUG 2016-10-10 16:26:19,035 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x91, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x8D] has been received.
DEBUG 2016-10-10 16:26:19,036 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0x91, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:26:19,037 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.937’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:26:24,034 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:26:24,034 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x83]
DEBUG 2016-10-10 16:26:24,035 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x83] has been received.
DEBUG 2016-10-10 16:26:24,036 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:26:24,037 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.951’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:26:29,034 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:26:29,034 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9B, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x87]
DEBUG 2016-10-10 16:26:29,035 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9B, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x87] has been received.
DEBUG 2016-10-10 16:26:29,036 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9B, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:26:29,037 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.947’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:26:34,039 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:26:34,039 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x96, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x8A]
DEBUG 2016-10-10 16:26:34,040 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x96, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x8A] has been received.
DEBUG 2016-10-10 16:26:34,041 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0x96, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:26:34,042 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.942’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:26:39,035 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:26:39,035 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x82]
DEBUG 2016-10-10 16:26:39,036 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x82] has been received.
DEBUG 2016-10-10 16:26:39,037 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:26:39,038 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.95’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:26:44,035 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:26:44,035 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x83]
DEBUG 2016-10-10 16:26:44,036 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x83] has been received.
DEBUG 2016-10-10 16:26:44,037 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:26:44,038 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.951’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:26:49,035 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:26:49,035 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA3, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xBF]
DEBUG 2016-10-10 16:26:49,036 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA3, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xBF] has been received.
DEBUG 2016-10-10 16:26:49,037 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA3, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:26:49,038 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.955’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:26:49,261 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:26:49,261 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x0C, 0x00, 0x04, 0x00, 0x06, 0x06, 0x31, 0x05, 0x03, 0x0A, 0x00, 0x04, 0xCE]
DEBUG 2016-10-10 16:26:49,262 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x0C, 0x00, 0x04, 0x00, 0x06, 0x06, 0x31, 0x05, 0x03, 0x0A, 0x00, 0x04, 0xCE] has been received.
DEBUG 2016-10-10 16:26:54,036 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:26:54,036 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x83]
DEBUG 2016-10-10 16:26:54,037 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x83] has been received.
DEBUG 2016-10-10 16:26:54,038 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:26:54,039 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.951’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:26:59,036 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:26:59,036 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA2, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xBE]
DEBUG 2016-10-10 16:26:59,037 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA2, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xBE] has been received.
DEBUG 2016-10-10 16:26:59,038 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA2, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:26:59,039 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.954’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:27:02,201 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:27:02,202 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x0C, 0x00, 0x04, 0x00, 0x06, 0x06, 0x31, 0x05, 0x01, 0x22, 0x00, 0xCA, 0x2A]
DEBUG 2016-10-10 16:27:02,202 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x0C, 0x00, 0x04, 0x00, 0x06, 0x06, 0x31, 0x05, 0x01, 0x22, 0x00, 0xCA, 0x2A] has been received.
DEBUG 2016-10-10 16:27:04,036 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:27:04,036 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9A, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x86]
DEBUG 2016-10-10 16:27:04,037 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9A, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x86] has been received.
DEBUG 2016-10-10 16:27:04,038 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9A, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:27:04,039 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.946’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:27:09,037 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:27:09,037 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80]
DEBUG 2016-10-10 16:27:09,038 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80] has been received.
DEBUG 2016-10-10 16:27:09,039 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:27:09,039 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.948’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:27:14,037 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:27:14,037 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA4, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xB8]
DEBUG 2016-10-10 16:27:14,038 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA4, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xB8] has been received.
DEBUG 2016-10-10 16:27:14,039 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA4, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:27:14,040 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.956’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:27:19,037 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:27:19,037 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA5, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xB9]
DEBUG 2016-10-10 16:27:19,038 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA5, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xB9] has been received.
DEBUG 2016-10-10 16:27:19,039 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA5, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:27:19,039 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.957’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:27:24,037 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:27:24,038 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x83]
DEBUG 2016-10-10 16:27:24,038 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x83] has been received.
DEBUG 2016-10-10 16:27:24,039 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:27:24,040 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.951’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:27:29,038 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:27:29,038 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA1, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xBD]
DEBUG 2016-10-10 16:27:29,039 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA1, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xBD] has been received.
DEBUG 2016-10-10 16:27:29,040 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA1, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:27:29,040 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.953’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:27:34,042 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:27:34,043 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80]
DEBUG 2016-10-10 16:27:34,043 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80] has been received.
DEBUG 2016-10-10 16:27:34,044 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:27:34,045 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.948’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:27:39,038 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:27:39,038 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x8C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x90]
DEBUG 2016-10-10 16:27:39,039 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x8C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x90] has been received.
DEBUG 2016-10-10 16:27:39,040 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0x8C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:27:39,041 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.932’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:27:40,977 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:27:40,978 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x0C, 0x00, 0x04, 0x00, 0x04, 0x06, 0x31, 0x05, 0x01, 0x42, 0x07, 0xC9, 0x4C]
DEBUG 2016-10-10 16:27:40,978 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x0C, 0x00, 0x04, 0x00, 0x04, 0x06, 0x31, 0x05, 0x01, 0x42, 0x07, 0xC9, 0x4C] has been received.
DEBUG 2016-10-10 16:27:41,001 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:27:41,001 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x10, 0x00, 0x04, 0x00, 0x04, 0x0A, 0x60, 0x0D, 0x02, 0x02, 0x31, 0x05, 0x01, 0x42, 0x07, 0xC9, 0x31]
DEBUG 2016-10-10 16:27:41,002 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x10, 0x00, 0x04, 0x00, 0x04, 0x0A, 0x60, 0x0D, 0x02, 0x02, 0x31, 0x05, 0x01, 0x42, 0x07, 0xC9, 0x31] has been received.
DEBUG 2016-10-10 16:27:44,041 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0xAB, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:27:44,042 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.963’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:27:49,039 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:27:49,039 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA9, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xB5]
DEBUG 2016-10-10 16:27:49,040 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA9, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xB5] has been received.
DEBUG 2016-10-10 16:27:49,041 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0xA9, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:27:49,042 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.961’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:27:54,040 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:27:54,040 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xB0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xAC]
DEBUG 2016-10-10 16:27:54,041 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xB0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xAC] has been received.
DEBUG 2016-10-10 16:27:54,042 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0xB0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:27:54,043 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.968’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:27:59,040 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:27:59,040 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x83]
DEBUG 2016-10-10 16:27:59,041 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x83] has been received.
DEBUG 2016-10-10 16:27:59,042 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0x9F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:27:59,042 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.951’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
DEBUG 2016-10-10 16:28:04,040 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-10-10 16:28:04,040 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xAB, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xB7]
DEBUG 2016-10-10 16:28:04,041 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x14, 0x00, 0x04, 0x00, 0x07, 0x0E, 0x32, 0x02, 0xA1, 0x6C, 0x00, 0x00, 0x07, 0xAB, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xB7] has been received.
DEBUG 2016-10-10 16:28:04,042 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_METER’, Command=‘0x02’, Parameters: [0xA1, 0x6C, 0x00, 0x00, 0x07, 0xAB, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00]]
DEBUG 2016-10-10 16:28:04,043 (Z-Wave): CCMeterV2 : Node ‘7:0’ : [COMMAND_CLASS_METER::METER_REPORT, Type=‘ELECTRIC_METER’, Scale=‘ELECTRIC_METER_SCALE_A’, Value=‘1.963’, PreviousValue=‘0’, Delta=‘0’, RateType=‘Import’].
Thank you.
aeo_hem1_100a.pdf (208 KB)
zwave-debug.log (363 KB)
zwave-debug.log.1 (500 KB)
