I am a beginner, for private use at home. I am on ubuntu 17.10, JDK 9 (I’ve tried 8 as well).
I have got as far as creating the Hello World panel, installing and running the controller, and running the mobile (android) app. That app does find the controller (although I’m confused as to whether I should be on port 8688 or 8080 - the former seems to work but the app says the latter is correct).
The next step is to sync the design with the controller. The MAC address is correct, but if I try to add it to the designer web page I get error:
No controller with the given MAC address was found or maybe it’s linked already.
Please start your controller before linking it, make sure it is not linked yet and that it has internet access.
I don’t know if this is because it’s already linked, but it isn’t listed. It is started, and I tried stopping and starting.
If I try to sync I get the following on the controller terminal. It seems to indicate that ssl is missing. This seems most unlikely, but what else can it be?
INFO 2018-04-12 15:58:02,812 : Starting device discovery service…
ERROR 2018-04-12 15:58:31,034 : Synchronizing controller with online account failed : Downloading account configuration failed : java.security.NoSuchAlgorithmException: Error constructing implementation (algorithm: Default, provider: SunJSSE, class: sun.security.ssl.SSLContextImpl$DefaultSSLContext)
org.openremote.controller.exception.ConnectionException: Downloading account configuration failed : java.security.NoSuchAlgorithmException: Error constructing implementation (algorithm: Default, provider: SunJSSE, class: sun.security.ssl.SSLContextImpl$DefaultSSLContext)
at org.openremote.controller.service.Deployer$BeehiveConnection.downloadZip(Deployer.java:1848)
at org.openremote.controller.service.Deployer$BeehiveConnection.access$300(Deployer.java:1701)
at org.openremote.controller.service.Deployer.deployFromOnline(Deployer.java:555)
at org.openremote.controller.action.ConfigManageController.syncOnline(ConfigManageController.java:140)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:445)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:382)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:859)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:793)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:476)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:441)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.openremote.controller.rest.support.json.JSONCallbackFilter.doFilter(JSONCallbackFilter.java:63)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:96)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:75)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:354)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
at java.base/java.lang.Thread.run(Thread.java:844)
Caused by: java.net.SocketException: java.security.NoSuchAlgorithmException: Error constructing implementation (algorithm: Default, provider: SunJSSE, class: sun.security.ssl.SSLContextImpl$DefaultSSLContext)
at java.base/javax.net.ssl.DefaultSSLSocketFactory.throwException(SSLSocketFactory.java:263)
at java.base/javax.net.ssl.DefaultSSLSocketFactory.createSocket(SSLSocketFactory.java:270)
at java.base/sun.net.www.protocol.https.HttpsClient.createSocket(HttpsClient.java:413)
at java.base/sun.net.NetworkClient.doConnect(NetworkClient.java:162)
at java.base/sun.net.www.http.HttpClient.openServer(HttpClient.java:474)
at java.base/sun.net.www.http.HttpClient.openServer(HttpClient.java:569)
at java.base/sun.net.www.protocol.https.HttpsClient.(HttpsClient.java:265)
at java.base/sun.net.www.protocol.https.HttpsClient.New(HttpsClient.java:372)
at java.base/sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(AbstractDelegateHttpsURLConnection.java:191)
at java.base/sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1181)
at java.base/sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1075)
at java.base/sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:177)
at java.base/sun.net.www.protocol.https.HttpsURLConnectionImpl.connect(HttpsURLConnectionImpl.java:163)
at org.openremote.controller.service.Deployer$BeehiveConnection.downloadZip(Deployer.java:1794)
… 38 more
