Hi there. When trying to create a rule for a thing asset and you then select that thing for a rule, there are no attributes available at all.
Its just an empty list. Any idea? Its the same on two different installations.
As you can see here, when you click on the attribute dropdown, it is empty.
Note that the attributes of the asset require the configuration item ‘rule state’ to be available for rules.
Thank you Pierre. That solved it.
