Thanks Michal- that took care of all the import errors and the rule is not getting added successfully to the Drools engine. However, upon execution of the command, it is throwing these errors ( i have verified t he username passwords are correct):
ERROR 2017-03-18 09:42:10,539 : Error in executing rule : Send mail sensor:Exception executing consequence for rule “Send mail” in org.openremote.controller.model.event: java.lang.RuntimeException: javax.mail.AuthenticationFailedException: 534-5.7.14 <https://accounts.google.com/signin/continue?sarp=1&scc=1&plt=AKgnsbut
534-5.7.14 -V0bbDuiQjk5qgZ7rNf0JgsDhF3pPPVFO8z3xDABB3_aw-ViyvVypT2dkevaNT3GftcoVD
534-5.7.14 ZDSCvvHbQsEnwt2ZO7IxdaqruBliGgo86LmTabX5PW3GrQpAqEbRPVRPZXWFuO8XVtZcpb
534-5.7.14 NXvvyuckZ2oYEW_0co3up3Fzt4FKnDTZAkYQCZ0uTCmPKH2oDHIhT-3VliE2K6qpQNNkFQ
534-5.7.14 UHfsYYWHAIz8ejxTdGleqDyIFZhfY> Please log in via your web browser and
534-5.7.14 then try again.
534-5.7.14 Learn more at
534 5.7.14 https://support.google.com/mail/answer/78754 z42sm8153108qtb.20 - gsmtp
Event Switch Event (ID = 400986, Source = ‘Send mail sensor’, Switch Value = ‘on’, Switch State = ON) not processed!
at org.drools.core.runtime.rule.impl.DefaultConsequenceExceptionHandler.handleException(DefaultConsequenceExceptionHandler.java:39)
at org.drools.core.common.DefaultAgenda.fireActivation(DefaultAgenda.java:1100)
at org.drools.core.phreak.RuleExecutor.fire(RuleExecutor.java:121)
at org.drools.core.phreak.RuleExecutor.evaluateNetworkAndFire(RuleExecutor.java:74)
at org.drools.core.common.DefaultAgenda.fireNextItem(DefaultAgenda.java:1007)
at org.drools.core.common.DefaultAgenda.fireLoop(DefaultAgenda.java:1350)
at org.drools.core.common.DefaultAgenda.fireAllRules(DefaultAgenda.java:1288)
at org.drools.core.impl.StatefulKnowledgeSessionImpl.internalFireAllRules(StatefulKnowledgeSessionImpl.java:1306)
at org.drools.core.impl.StatefulKnowledgeSessionImpl.fireAllRules(StatefulKnowledgeSessionImpl.java:1297)
at org.drools.core.impl.StatefulKnowledgeSessionImpl.fireAllRules(StatefulKnowledgeSessionImpl.java:1278)
at org.openremote.controller.statuscache.rules.RuleEngine.push(RuleEngine.java:203)
at org.openremote.controller.statuscache.EventProcessorChain.push(EventProcessorChain.java:196)
at org.openremote.controller.statuscache.StatusCache.update(StatusCache.java:293)
at org.openremote.controller.model.sensor.Sensor.update(Sensor.java:367)
at org.openremote.controller.model.sensor.Sensor$DeviceReader.run(Sensor.java:655)
Caused by: java.lang.RuntimeException: javax.mail.AuthenticationFailedException: 534-5.7.14 <https://accounts.google.com/signin/continue?sarp=1&scc=1&plt=AKgnsbut
at org.openremote.controller.model.event.Rule_Send_mail1794327546.defaultConsequence(Rule_Send_mail1794327546.java:38)
at org.openremote.controller.model.event.Rule_Send_mail1794327546DefaultConsequenceInvokerGenerated.evaluate(Unknown Source)
at org.openremote.controller.model.event.Rule_Send_mail1794327546DefaultConsequenceInvoker.evaluate(Unknown Source)
at org.drools.core.common.DefaultAgenda.fireActivation(DefaultAgenda.java:1089)
… 14 more
Caused by: javax.mail.AuthenticationFailedException: 534-5.7.14 <https://accounts.google.com/signin/continue?sarp=1&scc=1&plt=AKgnsbut
at com.sun.mail.smtp.SMTPTransport$Authenticator.authenticate(SMTPTransport.java:932)
at com.sun.mail.smtp.SMTPTransport.authenticate(SMTPTransport.java:843)
at com.sun.mail.smtp.SMTPTransport.protocolConnect(SMTPTransport.java:748)
at javax.mail.Service.connect(Service.java:388)
at javax.mail.Service.connect(Service.java:246)
at javax.mail.Service.connect(Service.java:195)
at javax.mail.Transport.send0(Transport.java:254)
at javax.mail.Transport.send(Transport.java:124)
at org.openremote.controller.model.event.Rule_Send_mail1794327546.defaultConsequence(Rule_Send_mail1794327546.java:33)
… 17 more
ERROR [Polling Sensor Thread ID = 400986, Name =‘Send mail sensor’]: Error in executing rule : Send mail sensor:Exception executing consequence for rule “Send mail” in org.openremote.controller.model.event: java.lang.RuntimeException: javax.mail.AuthenticationFailedException: 534-5.7.14 <https://accounts.google.com/signin/continue?sarp=1&scc=1&plt=AKgnsbut
… 14 more
… 17 more
ERROR 2017-03-18 09:42:10,549 : Root Cause:
… 17 more
ERROR [Polling Sensor Thread ID = 400986, Name =‘Send mail sensor’]: Root Cause:
