Are there any options to running this locally on prem as opposed to running this on the cloud for high availability? Say running this locally on a container orchestrator like kubernetes.
Or would it be better to run openremote on the cloud and rely on the cloud provider for HA?
Time ago I was busy with setting up HA configuration both with Docker Swarm and K8. This is discontinued at the moment and I’m afraid that there is no HA setup available (I might be wrong though). Even the available AWS deployment is a single VM deployment with its own reverse proxy, therefore it is simple to run it on prem. Nevertheless, HA you should configure yourself.
