OpenRemote 2.6.0 running as a Service on Win10
I am new user of ORController and I am not an accomplished programmer so please bear with me.
I am trying to install ORC2.6.0B3 with Tomcat8 running on Win10 as a Service. I have Java jre1.8.0_131
I have successfully had TC8 running some other simple web apps as a Service.
To get the controller installed I Installed TC8 as a Service and simply copied the ORC2.6.0 webapps contents to the TC8 webapps folder.
Each time I try and start the service I get an error as logged below and any attempt to sync OpenRemote controller results in an error “An attempt was made to access service context before it was initialized.”
I have successfully installed ORC 2.1.1 as a Service using the above technique but ORC2.5.0 and ORC2.6.0 both fail as described above.
Application initialization failed:
Invalid bean definition with name ‘configuration’ defined in class path resource [applicationContext.xml]: Could not resolve placeholder ‘openremote.sync.service.uri’
org.springframework.beans.factory.BeanDefinitionStoreException: Invalid bean definition with name ‘configuration’ defined in class path resource [applicationContext.xml]: Could not resolve placeholder ‘openremote.sync.service.uri’
at org.springframework.beans.factory.config.PropertyPlaceholderConfigurer.processProperties(PropertyPlaceholderConfigurer.java:249)
at org.springframework.beans.factory.config.PropertyResourceConfigurer.postProcessBeanFactory(PropertyResourceConfigurer.java:74)
at org.springframework.context.support.AbstractApplicationContext.invokeBeanFactoryPostProcessors(AbstractApplicationContext.java:472)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:334)
at org.springframework.context.support.ClassPathXmlApplicationContext.(ClassPathXmlApplicationContext.java:122)
at org.springframework.context.support.ClassPathXmlApplicationContext.(ClassPathXmlApplicationContext.java:76)
at org.openremote.controller.spring.SpringContext.(SpringContext.java:74)
at org.openremote.controller.spring.SpringContext.(SpringContext.java:69)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.openremote.controller.bootstrap.Startup.loadServiceContext(Startup.java:85)
at org.openremote.controller.bootstrap.servlet.ServletStartup.initializeServiceContext(ServletStartup.java:195)
at org.openremote.controller.bootstrap.servlet.ServletStartup.contextInitialized(ServletStartup.java:109)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4745)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5207)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:752)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:728)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:734)
at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:1107)
at org.apache.catalina.startup.HostConfig$DeployDirectory.run(HostConfig.java:1841)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
30-Apr-2017 11:52:06.280 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Projects\SmartHome\OpenRemoteTC8\webapps\controller has finished in 9,523 ms
Further info…
stderr log after startup…
2017-05-01 10:02:53 Commons Daemon procrun stderr initialized
01-May-2017 10:02:54.671 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version: Apache Tomcat/8.5.14
01-May-2017 10:02:54.687 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Apr 13 2017 12:55:45 UTC
01-May-2017 10:02:54.687 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number: 8.5.14.0
01-May-2017 10:02:54.687 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Windows 10
01-May-2017 10:02:54.687 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 10.0
01-May-2017 10:02:54.687 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: x86
01-May-2017 10:02:54.687 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: C:\Program Files (x86)\Java\jre1.8.0_131
01-May-2017 10:02:54.687 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_131-b11
01-May-2017 10:02:54.687 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation
01-May-2017 10:02:54.687 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: C:\Projects\SmartHome\OpenRemoteTC8
01-May-2017 10:02:54.687 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: C:\Projects\SmartHome\OpenRemoteTC8
01-May-2017 10:02:54.687 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\Projects\SmartHome\OpenRemoteTC8
01-May-2017 10:02:54.687 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\Projects\SmartHome\OpenRemoteTC8
01-May-2017 10:02:54.687 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\Projects\SmartHome\OpenRemoteTC8\temp
01-May-2017 10:02:54.687 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
01-May-2017 10:02:54.687 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\Projects\SmartHome\OpenRemoteTC8\conf\logging.properties
01-May-2017 10:02:54.687 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: exit
01-May-2017 10:02:54.687 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms128m
01-May-2017 10:02:54.687 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx256m
01-May-2017 10:02:54.687 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent Loaded APR based Apache Tomcat Native library 1.2.12 using APR version 1.5.2.
01-May-2017 10:02:54.687 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent APR capabilities: IPv6 [true], sendfile [true], accept filters [false], random [true].
01-May-2017 10:02:54.687 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent APR/OpenSSL configuration: useAprConnector [false], useOpenSSL [true]
01-May-2017 10:02:55.557 INFO [main] org.apache.catalina.core.AprLifecycleListener.initializeSSL OpenSSL successfully initialized (OpenSSL 1.0.2k 26 Jan 2017)
01-May-2017 10:02:55.737 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler [“http-nio-8688”]
01-May-2017 10:02:55.980 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
01-May-2017 10:02:55.996 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler [“ajp-nio-8009”]
01-May-2017 10:02:55.996 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
01-May-2017 10:02:55.996 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 1837 ms
01-May-2017 10:02:56.027 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina
01-May-2017 10:02:56.027 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.5.14
01-May-2017 10:02:56.074 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive C:\Projects\SmartHome\OpenRemoteTC8\webapps\webconsole.war
01-May-2017 10:02:57.996 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
01-May-2017 10:02:58.043 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deployment of web application archive C:\Projects\SmartHome\OpenRemoteTC8\webapps\webconsole.war has finished in 1,969 ms
01-May-2017 10:02:58.043 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Projects\SmartHome\OpenRemoteTC8\webapps\controller
01-May-2017 10:03:06.403 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
01-May-2017 10:03:06.700 INFO [localhost-startStop-1] org.openremote.controller.bootstrap.Startup.redirectJULtoLog4j Initialized JUL to LOG4J Redirector.
01-May-2017 10:03:08.412 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Projects\SmartHome\OpenRemoteTC8\webapps\controller has finished in 10,369 ms
01-May-2017 10:03:08.412 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Projects\SmartHome\OpenRemoteTC8\webapps\manager
01-May-2017 10:03:08.459 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Projects\SmartHome\OpenRemoteTC8\webapps\manager has finished in 47 ms
01-May-2017 10:03:08.475 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler [“http-nio-8688”]
01-May-2017 10:03:08.475 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler [“ajp-nio-8009”]
01-May-2017 10:03:08.490 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 12490 ms
and stdout log after running controller web app…
2017-05-01 10:02:53 Commons Daemon procrun stdout initialized
ERROR 2017-05-01 10:05:51,375 : Synchronizing controller with online account failed : An attempt was made to access service context before it was initialized.
java.lang.IllegalStateException: An attempt was made to access service context before it was initialized.
at org.openremote.controller.service.ServiceContext.getInstance(ServiceContext.java:458)
at org.openremote.controller.service.ServiceContext.getDeployer(ServiceContext.java:312)
at org.openremote.controller.action.ConfigManageController.syncOnline(ConfigManageController.java:140)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:445)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:382)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:859)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:793)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:476)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:441)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:661)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:742)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at org.openremote.controller.rest.support.json.JSONCallbackFilter.doFilter(JSONCallbackFilter.java:63)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:96)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:75)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:198)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:478)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:80)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:624)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:799)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:861)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1455)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
ERROR [http-nio-8688-exec-1]: Synchronizing controller with online account failed : An attempt was made to access service context before it was initialized.
Has anyone out there successfully run 2.6.0 as a service on Win10?
