Facing problem to Run Openremote.
- Prepaire environment link Developer Guide: Preparing the environment · openremote/openremote Wiki · GitHub
2 Install docker
3 IDE Setting Developer Guide: Setting up an IDE · openremote/openremote Wiki · GitHub
a) Run the command successfully
b) Set code on Intellij IDE and follow the instruction
c) after that when i Run the command
It give below error.
- Network openremote_default Created 0.7s
- Container openremote-postgresql-1 Healthy 11.9s
- Container openremote-keycloak-1 Started 18.4s
PS C:\Users\procu\Downloads\openremote-master\openremote-master> ./gradlew clean installDist
Starting a Gradle Daemon (subsequent builds will be faster)
- Try:
Run with --stacktrace option to get the stack trace.
Run with --info or --debug option to get more log output.
Run with --scan to get full insights.
- Get more help at https://help.gradle.org
Deprecated Gradle features were used in this build, making it incompatible with Gradle 8.0.
You can use ‘–warning-mode all’ to show the individual deprecation warnings and determine if they come from your own scripts or plugins.
BUILD FAILED in 26s
How I can solve the error where i have done mistake. Please Let me know.
Thank you
