OpenRemote Install Error
I’m trying to install the Openremote V3 so I followed the get start steps one by one, I’ve prepared the environment as stated in step 1 and I’ve cloned the source code folder.
After running the command : “docker-compose pull” as stated in the quick start tutorial I get this error :
ERROR: build path C:\Users\bhami\openremote\manager\build\install\manager either does not exist, is not accessible, or is not a valid URL.
Please help
Already replied to you directly but putting here for other users...
It's a long standing bug in docker which I've been hoping they'd fix sooner rather than later but I guess not.
Just create that folder it is looking for...it is a build artifact which isn't needed when pulling images from docker hub only when building the image from source but docker still looks for the directory (hence the bug).
Kind Regards,
Rich
