Openremote Keycloak Error
Whenever I use the command “docker-compose -p openremote up” everything runs fine but at the end it throws an error.I am mentioning the error below. Please help me with this.
ERROR:-
openremote-keycloak-1 exited with code 1
dependency failed to start: container openremote-keycloak-1 is unhealthy
Instead of docker-compose ; write docker compose
It will work for sure
Please share full logs of the startup process.
Keycloak crashed because it can’t connect to the postgresql database yet.
This is normal since the postgresql database is still being set up.
It should automatically try again / restart, but apparently it does not in your case?
