Hello Olivier,
Sorry it has taken me a few days to reply, I’ve been busy working on a client’s project.
I’m really hoping that you can get up and running with this simple CanvasJS based solution really quickly.
I’ll assume you are running a Linux based OS for your controller… If you are running a Windows based system then you will have to modify the csvmaker.sh file to turn it into a compatible BATCH (.bat) file. I’m sure it can be done, but I don’t know how. Maybe someone else can advise?
There are a few steps to follow to get this working.
You need a catch-all command in OpenRemote that a rule can send all the harvested data to, which in turn will pass the data to the Linux script file for conversion into appended csv files.
(For some reason I needed to map that command to a dummy custom sensor before it worked)
Sensors that produce numeric values, that have been named with the suffix .graph
Custom sensors can be used to map text entries to numeric values.
For example, I have Velbus devices that produce text outputs like “pressed” & “released”
I create custom sensors that map these to values.
10 = pressed
0 = released
A rule to catch all sensors with .graph at the end and push the data to the OpenRemote command.
First of all, I suggest that you download and unzip the this file into your webapps folder and test that you can access the graphs that it will create,
your finished webapps folder should have :-
controller
webconsole
jscanvas
Using a web browser, navigate to " http://{controller address}:8688/jscanvas "
You should see a simple 2 frame web page with a selection of graphs, produced from the CSV data. Similar to the PDF file attached,.
Once you have confirmed you can access the graphs, double check that the two script files within your jscanvas folder have their executable bits set.
chmod +x csvmaker.sh
chmod +x zipcsv.sh
you can test the csvmaker.sh script works correctly by using this command line instruction
./csvmaker.sh --value=12345 --file=test
You should now have a file in the csv folder called test.csv with a single line in it that has the time and date you actioned the script, a comma and the value 12345
Now copy the jscanvas_v1.drl file into your rules folder, so that when your controller restarts it will add the rule to the knowledge base.
…/…/webapps/controller/rules
The next part is to get OpenRemote to pass data.
Please create a command in designer that looks like this :-
Command name :-
csvmaker
Protocol :-
Shell execution protocol
path :-
#### Note that the path must be the exact path from root to the csvmaker.sh script file.
#### WITHOUT a preceding "."
#### Your path may differ from what is shown here
/opt/OpenRemote-Controller/webapps/jscanvas/csvmaker.sh
command :-
–value=${param}
Polling Interval ;- BLANK
Regular Expression :- BLANK
Sensor name :- (I found I have to create a custom sensor for this to work, which I called “Dummy”)
Dummy
Just because I did, please create a custom sensor names Dummy and link it to the csvmaker command that you created.
The final step in this process is modifying or creating sensors in your design that have the suffix .graph which the new rule will monitor and pass the values to the csvmaker script.
For some of my applications, this was as easy as renaming the sensor name and adding the suffix.
(Please double check your design UI points to this new sensor name, the name change does not filter to the UI automatically, in some cases this will require you to re-assign any images)
If the sensor is used in a slider, the slider will automatically be remapped to the new name,
Alternatively, create new sensors specifically for the graphing rule.
Once you have created all your sensors, please re-sync your controller to you design and watch for newly created *.graph.csv files in the csv subfolder of jscanvas
It is probably a good idea to clean out the csv files that were created when you unzipped, as it will make life easier when looking for your own data.
That said, I would leave them in there until you are happy that your new graphs are working.
This next step is a bit fiddly and will require some close attention to the coding, however, thanks to a fabulous bit of work by a a chap called Tom VC, it is much easier than when I first started.
There are two things you need to do.
First you need to edit the graphs.js file so that graphs are created using your new data.
Each line in the top part of graphs.js holds everything you need for a each graph,
Tom created a three section graph, if you only wish to show one bit of data per graph, simple replace the 2 other components with csv/dummy.csv
As shown in the last graphs in this file…
$(document).ready(function () {
Fill the array with all the graph info:
Title, current temp csv, target temp graph, relay graph, number of ms you want to show, name of the graph (for html file), zoom
1day=86400000 ms 7days=604800000 ms 30days=2592000000 ms
var graphData=[
/Master Bed LX 36 hours/ [“Master Bedroom Lights - Previous 36 hours”, “csv/dummy.csv”, “csv/master_mainlx.graph.csv”, “csv/dummy.csv”, 129600000, “MASTERLX”],
/Master Bed LX 30days/ [“Master Bedroom Lights - last 30 days”, “csv/dummy.csv”, “csv/master_mainlx.graph.csv”, “csv/dummy.csv”, 2592000000, “MASTERLX-30”],
/Master Bedroom 36 hours/ [“Master Bedroom - Previous 36 hours”, “csv/master_bed_current.graph.csv”, “csv/master_bed_target.graph.csv”, “csv/MB_heater.graph.csv”, 129600000, “MASTER”],
/Master Bedroom 30days/ [“Master Bedroom - last 30 days”, “csv/master_bed_current.graph.csv”, “csv/master_bed_target.graph.csv”, “csv/MB_heater.graph.csv”, 2592000000, “MASTER-30”],
/Mid bedroom 36 hours/ [“Middle bedroom - Previous 36 hours”, “csv/midbed_current.graph.csv”, “csv/midbed_target.graph.csv”, “csv/midbedroom-heater.graph.csv”, 129600000, “MID”],
/Mid bedroom 30 days/ [“Middle bedroom - last 30 days”, “csv/midbed_current.graph.csv”, “csv/midbed_target.graph.csv”, “csv/midbedroom-heater.graph.csv”, 2592000000, “MID-30”],
/Back bed 36 hours/ [“Back bedroom - Previous 36 hours”, “csv/backbed_current.graph.csv”, “csv/backbed_target.graph.csv”, “csv/back-bed-heater.graph.csv”, 129600000, “BACKBED”],
/Back Bed 30 days/ [“Back bedroom - last 30 days”, “csv/backbed_current.graph.csv”, “csv/backbed_target.graph.csv”, “csv/back-bed-heater.graph.csv”, 2592000000, “BACKBED-30”],
/Bath 36 hours/ [“Bathroom - Previous 36 hours”, “csv/bathroom-current.graph.csv”, “csv/bathroom-target.graph.csv”, “csv/bathroom-heater.graph.csv”, 129600000, “BATH”],
/Bath 30days/ [“Bathroom - last 30 days”, “csv/bathroom-current.graph.csv”, “csv/bathroom-target.graph.csv”, “csv/bathroom-heater.graph.csv”, 2592000000, “BATH-30”],
/Landing 36 hours/ [“Landing - Previous 36 hours”, “csv/landing-current.graph.csv”, “csv/landing-target.graph.csv”, “csv/landing-heater.graph.csv”, 129600000, “LAND”],
/Landing 30days/ [“Landing - last 30 days”, “csv/landing-current.graph.csv”, “csv/landing-target.graph.csv”, “csv/landing-heater.graph.csv”, 2592000000, “LAND-30”],
/Front 36 hours/ [“Front - Previous 36 hours”, “csv/frontroom-current.graph.csv”, “csv/frontroom-target.graph.csv”, “csv/frontroom-heater.graph.csv”, 129600000, “FRONT”],
/Front 30days/ [“Front - last 30 days”, “csv/frontroom-current.graph.csv”, “csv/frontroom-target.graph.csv”, “csv/frontroom-heater.graph.csv”, 2592000000, “FRONT-30”],
/Hallway 36 hours/ [“Hallway - Previous 36 hours”, “csv/hallway-current.graph.csv”, “csv/hallway-target.graph.csv”, “csv/hallway-heater.graph.csv”, 129600000, “HALL”],
/Hallway 30days/ [“Hallway - last 30 days”, “csv/hallway-current.graph.csv”, “csv/hallway-target.graph.csv”, “csv/hallway-heater.graph.csv”, 2592000000, “HALL-30”],
/TV 36 hours/ [“TV - Previous 36 hours”, “csv/tv_current.graph.csv”, “csv/tv_target.graph.csv”, “csv/TVHeater.graph.csv”, 129600000, “TV”],
/TV 30days/ [“TV - last 30 days”, “csv/tv_current.graph.csv”, “csv/tv_target.graph.csv”, “csv/TVHeater.graph.csv”, 2592000000, “TV-30”],
/Dining 36 hours/ [“Dining room - Previous 36 hours”, “csv/dining_current.graph.csv”, “csv/dining_target.graph.csv”, “csv/dining-heater.graph.csv”, 129600000, “DIN”],
/Dining 30days/ [“Dining room - last 30 days”, “csv/dining_current.graph.csv”, “csv/dining_target.graph.csv”, “csv/dining-heater.graph.csv”, 2592000000, “DIN-30”],
/Kitchen 36 hours/ [“Kitchen - Previous 36 hours”, “csv/Kitchen-Current-temp.graph.csv”, “csv/Kitchen-Temp-Target.graph.csv”, “csv/Kitchen-Heater.graph.csv”, 129600000, “KITCHEN”],
/Kitchen 30days/ [“Kitchen - last 30 days”, “csv/Kitchen-Current-temp.graph.csv”, “csv/Kitchen-Temp-Target.graph.csv”, “csv/Kitchen-Heater.graph.csv”, 2592000000, “KITCHEN-30”],
/Electricity 36 hours/ [“Electricity Previous 36 hours”, “csv/electric-instant.graph.csv”, “csv/dummy.csv”, “csv/dummy.csv”, 129600000, “ELEC”],
/Electricity 30days/ [“Electricity Previous - Last 30 days”, “csv/electric-instant.graph.csv”, “csv/dummy.csv”, “csv/dummy.csv”, 2592000000, “ELEC-30”],
/Gas Instant 36 hours/ [“Gas Instant - Previous 36 hours”, “csv/gas-instant.graph.csv”, “csv/dummy.csv”, “csv/heatdemand.graph.csv”, 129600000, “GAS”],
/Gas Instant 30 days/ [“Gas Instant - Last 30 days”, “csv/gas-instant.graph.csv”, “csv/dummy.csv”, “csv/dummy.csv”, 2592000000, “GAS-30”],
/Water Instant 36 hours/ [“Water Instant - Previous 36 hours”, “csv/dummy.csv”, “csv/water-instant.graph.csv”, “csv/dummy.csv”, 129600000, “WATER”],
/Water Instant 30 days/ [“Water instant - Last 30 days”, “csv/dummy.csv”, “csv/water-instant.graph.csv”, “csv/dummy.csv”, 2592000000, “WATER-30”],
/HOT Water Instant 36 hours/ [“Hot Water - Previous 36 hours”, “csv/hot-water-instant.graph.csv”, “csv/dummy.csv”, “csv/dummy.csv”, 129600000, “HOT-WATER”],
/HOT Water instant 30 days/ [“Hot Water - Last 30 days”, “csv/hot-water-instant.graph.csv”, “csv/dummy.csv”, “csv/dummy.csv”, 2592000000, “HOT-WATER-30”],
/HOT Both Water 36 hours/ [“BOTH Water - Previous 36 hours”, “csv/hot-water-instant.graph.csv”, “csv/water-instant.graph.csv”, “csv/dummy.csv”, 129600000, “BOTH-WATER”],
/Boiler 36 hours/ [“Boiler demand 36 hours”, “csv/dummy.csv”, “csv/heatdemand.graph.csv”, “csv/boiler.graph.csv”, 129600000, “BOILER”],
/Boiler 30 days/ [“Boiler demand - Last 30 days”, “csv/dummy.csv”, “csv/heatdemand.graph.csv”, “csv/boiler.graph.csv”, 2592000000, “BOILER-30”],
/External Temp 36 hours/ [“External Temperature - 36 hours”, “csv/METEO-Temp.graph.csv”, “csv/dummy.csv”, “csv/dummy.csv”, 129600000, “EXTTEMP”],
/External Temp 30 days/ [“External Temperature - Last 30 days”, “csv/METEO-Temp.graph.csv”, “csv/dummy.csv”, “csv/dummy.csv”, 2592000000, “EXTTEMP-30”],
/Light level 36 hours/ [“Light - 36 hours”, “csv/METEO-LUX.graph.csv”, “csv/dummy.csv”, “csv/dummy.csv”, 129600000, “LUX”],
/Light Level 30 days/ [“Light - Last 30 days”, “csv/METEO-LUX.graph.csv”, “csv/dummy.csv”, “csv/dummy.csv”, 2592000000, “LUX-30”],
/Wind 36 hours/ [“Wind - 36 hours”, “csv/METEO-Wind-KH.graph.csv”, “csv/dummy.csv”, “csv/dummy.csv”, 129600000, “WIND-KH”],
/Wind 30 days/ [“Wind - Last 30 days”, “csv/METEO-Wind-KH.graph.csv”, “csv/dummy.csv”, “csv/dummy.csv”, 2592000000, “WIND-KH-30”],
/Rain 36 hours/ [“Rain - 36 hours”, “csv/METEO-Rain.graph.csv”, “csv/dummy.csv”, “csv/dummy.csv”, 129600000, “RAIN”],
/Rain 30 days/ [“Rain - Last 30 days”, “csv/METEO-Rain.graph.csv”, “csv/dummy.csv”, “csv/dummy.csv”, 2592000000, “RAIN-30”],
/External Temp 36 hours/ [“Rain - 36 hours”, “csv/METEO-RAIN.graph.csv”, “csv/dummy.csv”, “csv/dummy.csv”, 129600000, “RAIN”],
/External Temp 30 days/ [“Rain - Last 30 days”, “csv/METEO-RAIN.graph.csv”, “csv/dummy.csv”, “csv/dummy.csv”, 2592000000, “RAIN-30”],
/Velbus time out/ [“Velbus temperature intervals”, “csv/timeupcounter.graph.csv”, “csv/dummy.csv”, “csv/dummy.csv”, 2592000000, “Velbus”],
for (var k=0; k<graphData.length; k++){
makeGraph(graphData[k][0],graphData[k][1],graphData[k][2],graphData[k][3],graphData[k][4],graphData[k][5]);
function makeGraph(graphTitel,csvCurrent,csvTarget,csvRelay,numerOfMs,graphName){
var dataPoints1 = [];
var dataPoints2 = [];
var dataPoints3 = [];
$.ajax({
type: “GET”,
url: csvCurrent,
dataType: “text”,
success: function(data) {processData1(data);}
function processData1(allText) {
var allLinesArray = allText.split(’\n’);
if(allLinesArray.length>0){
for (var i = 1; i <= allLinesArray.length-1; i++) {
var line = allLinesArray[i].split(’,’);
if (dateDiff(line[0]) <= numerOfMs) {
dataPoints1.push({x: parseDate(line[0]),y:parseFloat(line[1])});
requestTempCsv();
function requestTempCsv() {
$.ajax({
type: "GET",
url: csvTarget,
dataType: "text",
success: function (data) { processData2(data); }
function processData2(allText) {
dataPoints2.push({x: parseDate(line[0]),y:parseFloat(line[1])});
dataPoints2.push({x: new Date(),y:parseFloat(0)});
requestTempCsv2();
function requestTempCsv2() {
$.ajax({
type: "GET",
url: csvRelay,
dataType: "text",
success: function (data) { processData3(data); }
function processData3(allText) {
dataPoints3.push({x: parseDate(line[0]),y:parseFloat(line[1])});
dataPoints3.push({x: new Date(),y:parseFloat(0)});
drawChart(dataPoints1, dataPoints2, dataPoints3);
function drawChart(dataPoints1, dataPoints2, dataPoints3) {
var chart = new CanvasJS.Chart(graphName, {
theme: “theme2”,
title:{
text: graphTitel
backgroundColor: “#000000”,
axisX:{
labelAngle: 15,
valueFormatString: “DD/MMM - H:mm” ,
}, legend: {
horizontalAlign: “center”, verticalAlign: “bottom”,
fontColor: “#ffffff”,
fontSize: 15
data: [
type: "stepArea",
markerType: “none”,
dataPoints: dataPoints2
type: “line”,
markerType: “none”,
dataPoints: dataPoints1
type: “stepArea”,
markerType: “none”,
dataPoints: dataPoints3
exportEnabled: true,
zoomEnabled:true
chart.render();
function parseDate(line)
return new Date(line.slice(0,4), line.slice(5,7)-1, line.slice(8,10),line.slice(11,13),line.slice(14,16));
function dateDiff(line)
var dateToCheck = Date.UTC (line.slice(0,4), line.slice(5,7)-1, line.slice(8,10),line.slice(11,13)-1,line.slice(14,16));
return Date.now() - dateToCheck;
Once the graphs.js file has been edited, you will need to create
sections in your html code to display the graphs.
As shown here :-
<Title=“Wollaston Overview”>
body {
background-color: #000000;
Breakdown of Master Bedroom current temperatures
Open Back suite in another window
Open Back Bedroom in another window
RED Gas consumption.
GREEN Blocks show how many rooms are calling for heat.
Open GAS in another window
Open Electricity in another window
Open Combined Water in another window
Open external temperature in another window
Open Light level in another window
Open GP06 with heating demand in another window
Open GP07 with heating demand in another window
Velbus message updates
ONE MASSIVE TIP…
When you refresh your web browser after editing your graph.js file (or html file) keep in mind that it is unlikely that the graph.js file will be correctly refreshed !!!
This took me hours of pain to learn…
To resolve this, direct your web browser to:-
http://{controller address}:8688/jscanvas/graphs.js
Then press F5 or refresh…
This will force the browser to reload the graphs,js file.
It is also an opportunity to double check that your changes have made their way to your browser.
That should be it, you should be able to create as many graphs as you like.
Keep in mind that the CSV files can get quite big if you leave them for many months.
The zipcsv.sh script file will zip them up nicely and put the dummy.csv file back so that your new data will continue to work in the graphs.
(I’ve created a command in OpenRemote designer which is linked to a button so that I can zip the files from my OR UI )
Good luck
Stuart
jscanvas_v1.drl (1.07 KB)
jscanvas_a-overview.pdf (529 KB)
