I’m trying to deployment my OpenRemote project into App Web, by docker file docker-compose.yml. But its not working.
The error that accurs is:
upstream connect error or disconnect/reset before headers. retried and the latest reset reason: remote connection failure, transport failure reason: delayed connect error: 111
Can anyone help me about this issue?
apurba
February 7, 2024, 4:48am
2
hi,
share log and yml file .
docker-compose.yml.txt (2.5 KB)
The log is the message that I already share
apurba
February 7, 2024, 11:59am
4
hi ,
the extension should be .yml not .txt
change it to docker-compose.yml
This is not the case, I changed it so I could share it here.
I need help for the deplyment of OpenRemote in azure from scratch. Because I do not know how I do that.
Anyone that can help me if that even if paid I accept.
Or someone how knows or have this file please let me know:
https://github.com/openremote/openremote/blob/master/.ci_cd/aws/cloudformation-standard.yml
Rich
February 8, 2024, 12:55pm
6
I don’t have much experience with Azure but you just need a VPS (arm64 or amd64) running linux with docker engine and docker compose installed.
You can then run the stack using the docker-compose.yml from the repo.
There will be plenty of resources I’m sure for creating a VPS in Azure.
system
Closed
March 9, 2024, 12:56pm
7
