I have installed a Raspberry Pi and connected it to my Velbus installation to be able to control my domotica from handheld device by use of OpenRemote.
I am now testing somewhat in Openremote before setting up the final interface.
I succeeded in switching a light on/off and sending a screen up and down from my smartphone panel…
But I am not able to dim a light with module VMBDMI-R by use of a slider on my smartphone panel.
Is there a minimum level of Firmware needed for the VMBDMI-R ?
I checked and noticed that my VMBDMI-R has build 1515. I have bought them end 2016 and installed them in 2017.
If the firmware is not the problem, can you please give me a detailed example of the device / commands I need to config in OpenRemote to get my dimmer working.
Many thx in advance.
Problem slider OpenRemote.pdf (79.6 KB)
