I cannot remember if I included this module within the 2.5 Velbus protocol; there should be a velbus specific log file in the logs dir which will indicate what happened during module initialisation (search by module address), please post output here.
Thank for your reply. I Somehow missed the reply, Sorry for that.
And I am not sure if I understand your reply.
Do you mean the attached velbus.log or boot.log file?
The velbus.log says:
WARN 2019-08-31 11:14:57,739 (Velbus): Unkown command ‘246’ will be ignored
WARN 2019-08-31 11:16:57,821 (Velbus): Unkown command ‘246’ will be ignored
INFO 2019-08-31 13:41:20,375 (Velbus): Device is not reachable so not adding sensor
WARN 2019-08-31 13:45:00,036 (Velbus): Unkown command ‘246’ will be ignored
WARN 2019-08-31 13:55:00,040 (Velbus): Unkown command ‘245’ will be ignored
INFO 2019-08-31 14:31:34,092 (Velbus): Device is not reachable so cannot process command
INFO 2019-08-31 14:31:37,138 (Velbus): Device is not reachable so cannot process command
INFO 2019-08-31 14:31:39,007 (Velbus): Device is not reachable so cannot process command
INFO 2019-08-31 14:31:41,329 (Velbus): Device is not reachable so cannot process command
INFO 2019-08-31 14:31:43,055 (Velbus): Device is not reachable so cannot process command
INFO 2019-08-31 14:31:44,465 (Velbus): Device is not reachable so cannot process command
INFO 2019-08-31 14:31:45,667 (Velbus): Device is not reachable so cannot process command
the boot.log is attached. It says about the sensors:
These are 2 sensors it mention when starting openremote
INFO 2019-07-25 21:22:27,620 : Registered sensor : Sensor (Name = ‘253_01_SE_POSITION_STATUS’, ID = ‘873747’, State Mappings: {})
INFO 2019-07-25 21:22:27,620 : Registered sensor : Sensor (Name = ‘252_01_SE_POSITION_STATUS’, ID = ‘873746’, State Mappings: {})
