I setup an OpenRemote cluster using docker-compose.
I was able to login and setup an agent and a single LED asset.
I added an HTTP agent that is linked to the on/off attribute of my led.
I see an http query hit my led http server:
GET /?colourRGB=notavalidvalue HTTP/1.1.
Connection: Keep-Alive.
User-Agent: Apache-HttpClient/4.5.13 (Java/17.0.4).
I can see that OR is sending the HTTP query to the LED lights but I can’t get OpenRemote to pass the RGB value or the onOff value in the query.
I added the “Query Parameters” parameter to my agent link and set the value :
{colourRGB}
colourRGB being the attribute that holds the RGB value for the led asset.
When I do the above, I see the following error in the console of OR :
manager_1 | 2022-08-28 23:18:39.534 SEVERE [Messaging-ActuatorTopic-59 ] gent.protocol.http.HTTPProtocol.PROTOCOL : Exception thrown whilst doing attribute write request
manager_1 | javax.ws.rs.ProcessingException: java.lang.IllegalArgumentException: RESTEASY003720: path param this.colourRGB has not been provided by the parameter map
So clearly it’s being seen as a variable but it’s not resolving.
If I set the value to “notavalidvalue” I see that passed in the HTTP query.
How do I pass through the attributes of my asset as either GET parameters or Headers to the LED controller?
LED controller is a php script on a raspberry pi zero 2 w.
Thank you!
