Hi all,
I was wondering if it is possible to place a label above or below of the icon in the map of an asset, for example, the name of asset. Thanks!!
I know that that is possible when using the map widget in the insights tab, but I’m not sure about the main map. Hope this helps!
You can use the manager config to set per asset type which attribute to show as colour of the marker, with/without label, and with/without label (search on docs.openremote.io). You can not choose the name though, so you can add that as attribute so that you can show it?
