Error response from daemon: Ports are not available: exposing port TCP 0.0.0.0:80 → 0.0.0.0:0: listen tcp 0.0.0.0:80: bind: An attempt was made to access a socket in a way forbidden by its access permissions.
Hi. Thanks for the reply. Docker must run at port 80? Or can we change the docker port? Because there’s something running on my port 80 and I would like to keep this service running on port 80.
Yes you can change ports (unmap port 80 if necessary); port 80 is only used for auto TLS certificate generation. You can just use the built in self signed certificate or provide your own custom certificate(s).
