Problem enocean after migration from 2.1 to 2.5 (pro)
Best all,
I had running my enocean system from Eltako for 2 years now without problems in the controller 2.1.
After migration and running in the controller 2.5 i have the following message:
org.openremote.controller.exception.NoSuchCommandException: Unsupported EEP type ‘A5-38-08’.
at org.openremote.controller.protocol.enocean.EnOceanCommandBuilder.build(EnOceanCommandBuilder.java:292)
at org.openremote.controller.command.CommandFactory.getCommand(CommandFactory.java:164)
at org.openremote.controller.model.xml.Version20SensorBuilder.parseSensorEventProducer(Version20SensorBuilder.java:423)
at org.openremote.controller.model.xml.Version20SensorBuilder.build(Version20SensorBuilder.java:287)
at org.openremote.controller.deployer.Version20ModelBuilder.buildSensorObjectModelFromXML(Version20ModelBuilder.java:858)
at org.openremote.controller.deployer.Version20ModelBuilder.buildSensorModel(Version20ModelBuilder.java:701)
at org.openremote.controller.deployer.Version20ModelBuilder.build(Version20ModelBuilder.java:595)
at org.openremote.controller.deployer.AbstractModelBuilder.buildModel(AbstractModelBuilder.java:154)
at org.openremote.controller.service.Deployer.startup(Deployer.java:1057)
at org.openremote.controller.service.Deployer.softRestart(Deployer.java:456)
at org.openremote.controller.service.Deployer$ControllerDefinitionWatch.run(Deployer.java:1624)
at java.lang.Thread.run(Thread.java:695)
INFO 2016-08-09 21:28:16,124 : Registered sensor : Sensor (Name = ‘Sensor_Bel’, ID = ‘317342’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,124 : Registered sensor : Sensor (Name = ‘Sensor_Beltrafo’, ID = ‘317341’, State Mappings: {null=${state.getName()}, ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,125 : Registered sensor : Range Sensor (Name = ‘Sensor_switch_light’, ID = ‘317340’, Min: 0, Max: 90)
INFO 2016-08-09 21:28:16,125 : Registered sensor : Sensor (Name = ‘Sensor_ONOFF_L18’, ID = ‘317339’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,125 : Registered sensor : Sensor (Name = ‘Sensor_L16’, ID = ‘317338’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,125 : Registered sensor : Sensor (Name = ‘Sensor_WCD18’, ID = ‘317337’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,125 : Registered sensor : Sensor (Name = ‘Sensor_FPE1_L17’, ID = ‘317335’, State Mappings: {ROCKER_AI_0=on, ROCKER_AI=off})
INFO 2016-08-09 21:28:16,125 : Registered sensor : Sensor (Name = ‘Sensor_L17’, ID = ‘317334’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,125 : Registered sensor : Sensor (Name = ‘Sensor_WCD19’, ID = ‘317333’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,125 : Registered sensor : Sensor (Name = ‘Sensor_btn_overloop1’, ID = ‘317332’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,125 : Registered sensor : Sensor (Name = ‘Sensor_ONOFF_L19’, ID = ‘317331’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,125 : Registered sensor : Range Sensor (Name = ‘Sensor_vol’, ID = ‘317329’, Min: 0, Max: 50)
INFO 2016-08-09 21:28:16,126 : Registered sensor : Sensor (Name = ‘Sensor_frw3’, ID = ‘317328’, State Mappings: {ROCKER_AO=batt_empty, ROCKER_AI_0=off, N/A=off_start, ROCKER_AI=on})
INFO 2016-08-09 21:28:16,126 : Registered sensor : Sensor (Name = ‘Sensor_frw5’, ID = ‘317326’, State Mappings: {ROCKER_AO=batt_empty, ROCKER_AI_0=off, N/A=off_start, ROCKER_AI=on})
INFO 2016-08-09 21:28:16,126 : Registered sensor : Sensor (Name = ‘Sensor_frw2’, ID = ‘317327’, State Mappings: {ROCKER_AO=batt_empty, ROCKER_AI_0=off, N/A=off_start, ROCKER_AI=on})
INFO 2016-08-09 21:28:16,126 : Registered sensor : Sensor (Name = ‘Sensor_frw1’, ID = ‘317324’, State Mappings: {ROCKER_AO=batt_empty, ROCKER_AI_0=off, N/A=off_start, ROCKER_AI=on})
INFO 2016-08-09 21:28:16,126 : Registered sensor : Sensor (Name = ‘Sensor_frw4’, ID = ‘317325’, State Mappings: {ROCKER_AO=batt_empty, ROCKER_AI_0=off, N/A=off_start, ROCKER_AI=on})
INFO 2016-08-09 21:28:16,126 : Registered sensor : Range Sensor (Name = ‘Sensor_delay_douch’, ID = ‘317322’, Min: 1, Max: 30)
INFO 2016-08-09 21:28:16,126 : Registered sensor : Range Sensor (Name = ‘Sensor_delay_wc’, ID = ‘317323’, Min: 1, Max: 30)
INFO 2016-08-09 21:28:16,127 : Registered sensor : Sensor (Name = ‘Sensor_WCD16’, ID = ‘317320’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,127 : Registered sensor : Sensor (Name = ‘Sensor_WCD17’, ID = ‘317321’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,127 : Registered sensor : Sensor (Name = ‘Sensor_WCD14’, ID = ‘317318’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,127 : Registered sensor : Sensor (Name = ‘Sensor_WCD15’, ID = ‘317319’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,127 : Registered sensor : Range Sensor (Name = ‘Sensor_ventilation_Set’, ID = ‘317316’, Min: 0, Max: 3)
INFO 2016-08-09 21:28:16,127 : Registered sensor : Sensor (Name = ‘Sensor_WCD13’, ID = ‘317317’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,127 : Registered sensor : Range Sensor (Name = ‘Sensor_LIGHT_LB5’, ID = ‘317314’, Min: 0, Max: 255)
INFO 2016-08-09 21:28:16,127 : Registered sensor : Sensor (Name = ‘Sensor_ventilation’, ID = ‘317315’, State Mappings: {3=three, 2=two, 1=one, 0=off})
INFO 2016-08-09 21:28:16,128 : Registered sensor : Range Sensor (Name = ‘Sensor_POWER_LB4’, ID = ‘317312’, Min: 0, Max: 255)
INFO 2016-08-09 21:28:16,128 : Registered sensor : Range Sensor (Name = ‘Sensor_POWER_LB5’, ID = ‘317313’, Min: 0, Max: 255)
INFO 2016-08-09 21:28:16,128 : Registered sensor : Sensor (Name = ‘Sensor_ONOFF_L1’, ID = ‘317267’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,128 : Registered sensor : Sensor (Name = ‘Sensor_L15’, ID = ‘317264’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,128 : Registered sensor : Sensor (Name = ‘Sensor_text_wc’, ID = ‘317265’, State Mappings: {})
INFO 2016-08-09 21:28:16,128 : Registered sensor : Sensor (Name = ‘Sensor_ONOFF_L3’, ID = ‘317270’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,128 : Registered sensor : Sensor (Name = ‘Sensor_ONOFF_L2’, ID = ‘317268’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,128 : Registered sensor : Sensor (Name = ‘Sensor_ONOFF_L5’, ID = ‘317275’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,128 : Registered sensor : Sensor (Name = ‘Sensor_ONOFF_L4’, ID = ‘317272’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,128 : Registered sensor : Sensor (Name = ‘Sensor_ONOFF_L10’, ID = ‘317279’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,129 : Registered sensor : Sensor (Name = ‘Sensor_ONOFF_L6’, ID = ‘317276’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,129 : Registered sensor : Sensor (Name = ‘DateTime’, ID = ‘317254’, State Mappings: {})
INFO 2016-08-09 21:28:16,129 : Registered sensor : Sensor (Name = ‘Sensor_ONOFF_L8’, ID = ‘317259’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,129 : Registered sensor : Sensor (Name = ‘Sensor_btn_wc_up’, ID = ‘317258’, State Mappings: {ROCKER_BO=offdown, ROCKER_BI=on, ROCKER_BO_0=offup, ROCKER_BI_0=off})
INFO 2016-08-09 21:28:16,129 : Registered sensor : Sensor (Name = ‘Sensor_ONOFF_L9’, ID = ‘317256’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,129 : Registered sensor : Sensor (Name = ‘Sensor_FPE1_L15’, ID = ‘317263’, State Mappings: {ROCKER_AI_0=on, ROCKER_AI=off})
INFO 2016-08-09 21:28:16,129 : Registered sensor : Sensor (Name = ‘Sensor_ONOFF_L7’, ID = ‘317261’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,129 : Registered sensor : Sensor (Name = ‘Sensor_btn_wc’, ID = ‘317260’, State Mappings: {ROCKER_BO_0=on, ROCKER_BI_0=off})
INFO 2016-08-09 21:28:16,130 : Registered sensor : Sensor (Name = ‘Sensor_WCD12’, ID = ‘317296’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,130 : Registered sensor : Sensor (Name = ‘Sensor_btn_douch_up’, ID = ‘317297’, State Mappings: {ROCKER_AI_0=off, ROCKER_AI=on})
INFO 2016-08-09 21:28:16,130 : Registered sensor : Sensor (Name = ‘Sensor_relais1’, ID = ‘317298’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,130 : Registered sensor : Sensor (Name = ‘Sensor_btn_douch_down’, ID = ‘317299’, State Mappings: {ROCKER_AO=on, ROCKER_AO_0=off})
INFO 2016-08-09 21:28:16,130 : Registered sensor : Sensor (Name = ‘Sensor_relais3’, ID = ‘317300’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,130 : Registered sensor : Sensor (Name = ‘Sensor_relais2’, ID = ‘317301’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,130 : Registered sensor : Sensor (Name = ‘Sensor_relais0’, ID = ‘317302’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,130 : Registered sensor : Switch Sensor (Name = ‘Sensor_button_douch’, ID = ‘317303’)
INFO 2016-08-09 21:28:16,130 : Registered sensor : Range Sensor (Name = ‘Sensor_LIGHT_LB1’, ID = ‘317304’, Min: 0, Max: 255)
INFO 2016-08-09 21:28:16,130 : Registered sensor : Sensor (Name = ‘Sensor_MOTION_LB1’, ID = ‘317305’, State Mappings: {1=off, 0=on})
INFO 2016-08-09 21:28:16,130 : Registered sensor : Sensor (Name = ‘Sensor_MOTION_LB3’, ID = ‘317306’, State Mappings: {1=off, 0=on})
INFO 2016-08-09 21:28:16,131 : Registered sensor : Sensor (Name = ‘Sensor_MOTION_LB4’, ID = ‘317307’, State Mappings: {1=on, 0=off})
INFO 2016-08-09 21:28:16,131 : Registered sensor : Range Sensor (Name = ‘Sensor_POWER_LB3’, ID = ‘317308’, Min: 0, Max: 255)
INFO 2016-08-09 21:28:16,131 : Registered sensor : Sensor (Name = ‘Sensor_MOTION_LB5’, ID = ‘317309’, State Mappings: {1=on, 0=off})
INFO 2016-08-09 21:28:16,131 : Registered sensor : Range Sensor (Name = ‘Sensor_LIGHT_LB3’, ID = ‘317310’, Min: 0, Max: 255)
INFO 2016-08-09 21:28:16,131 : Registered sensor : Range Sensor (Name = ‘Sensor_LIGHT_LB4’, ID = ‘317311’, Min: 0, Max: 255)
INFO 2016-08-09 21:28:16,131 : Registered sensor : Sensor (Name = ‘Sensor_L11’, ID = ‘317280’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,131 : Registered sensor : Sensor (Name = ‘Sensor_L13’, ID = ‘317283’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,131 : Registered sensor : Sensor (Name = ‘Sensor_ONOFF_L12’, ID = ‘317282’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,131 : Registered sensor : Sensor (Name = ‘Sensor_WCD1’, ID = ‘317285’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,131 : Registered sensor : Sensor (Name = ‘Sensor_L14’, ID = ‘317284’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,132 : Registered sensor : Sensor (Name = ‘Sensor_WCD3’, ID = ‘317287’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,132 : Registered sensor : Sensor (Name = ‘Sensor_WCD2’, ID = ‘317286’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,132 : Registered sensor : Sensor (Name = ‘Sensor_WCD5’, ID = ‘317289’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,132 : Registered sensor : Sensor (Name = ‘Sensor_WCD4’, ID = ‘317288’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,132 : Registered sensor : Sensor (Name = ‘Sensor_WCD7’, ID = ‘317291’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,132 : Registered sensor : Sensor (Name = ‘Sensor_WCD6’, ID = ‘317290’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,132 : Registered sensor : Sensor (Name = ‘Status_WCD9’, ID = ‘317293’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,132 : Registered sensor : Sensor (Name = ‘Status_WCD8’, ID = ‘317292’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,132 : Registered sensor : Sensor (Name = ‘Sensor_WCD11’, ID = ‘317295’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,133 : Registered sensor : Sensor (Name = ‘Sensor_WCD10’, ID = ‘317294’, State Mappings: {ROCKER_BO=on, ROCKER_BI=off})
INFO 2016-08-09 21:28:16,149 : Startup complete.
INFO 2016-08-09 21:28:16,152 : Starting remote command service to https://designer.openremote.com/ccs/rest//commands/1…
WARN 2016-08-09 21:28:18,061 : Unable to connect to remote command service, retrying in 30.000 milliseconds. Connection error: Remote command service at ‘https://designer.openremote.com/ccs/rest//commands/1’ was not available or not found.
org.openremote.controller.exception.ConnectionException: Remote command service at ‘https://designer.openremote.com/ccs/rest//commands/1’ was not available or not found.
at org.openremote.controller.service.BeehiveCommandCheckService$BeehiveCommandChecker.httpRequest(BeehiveCommandCheckService.java:468)
at org.openremote.controller.service.BeehiveCommandCheckService$BeehiveCommandChecker.httpGet(BeehiveCommandCheckService.java:376)
at org.openremote.controller.service.BeehiveCommandCheckService$BeehiveCommandChecker.run(BeehiveCommandCheckService.java:247)
--------------------------------------------- START CONTROLLER ---------------------------------------------
2016.08.09 21:28:20 Init_ventilation
– Version 2016-04-22: V.1 –
