Hi, Rainer.
After upgrading to version 2.6.2 of the controller and get working RXTX for Z-Wave stick, I checked all my devices and found that the dimmer became not work correctly. Pressing the ON - it turns on, but the state of the sensor does not respond. OFF I have it I can not. Only if this is done the slider, but first increased and then reduced to 0.
Video: https://youtu.be/1bpUoX3WcCQ
In Designer 2.6.2 I removed all of the commands and sensors for this dimmer, save and then set up all over again, save. Synchronized with the controller. The result is the same as the dimmer is not working properly.
Z-wawe log for Node3 ONN and OFF command (switch Fibaro FGS-221 - normal working) and Node2 ONN and OFF command, and slider command (dimmer Fibaro FGD-211 - problem working):
DEBUG 2016-09-09 16:52:09,941 (Z-Wave): Command_Builder : Building Z-Wave command
DEBUG 2016-09-09 16:52:09,941 (Z-Wave): Command_Builder : Z-Wave command: nodeId = ‘3’, endPoint = ‘1’
DEBUG 2016-09-09 16:52:09,941 (Z-Wave): Command_Builder : Z-Wave command: command = ON
DEBUG 2016-09-09 16:52:09,941 (Z-Wave): Command_Builder : Z-Wave command: paramValue = null
DEBUG 2016-09-09 16:52:09,941 (Z-Wave): Command_Builder : Z-Wave command created successfully
DEBUG 2016-09-09 16:52:09,942 (Z-Wave): CCSwitchBinary : Node ‘3:1’ : [COMMAND_CLASS_SWITCH_BINARY::SWITCH_BINARY_SET, Value=‘255’]
DEBUG 2016-09-09 16:52:09,942 (Z-Wave): Controller_API : Enqueue (queue count=1) Z-Wave function call ‘org.openremote.protocol.zwave.model.commandclasses.CCMultiChannelV2FuncDecorator@17c24d7’.
DEBUG 2016-09-09 16:52:09,942 (Z-Wave): Controller_API : Dequeue (queue count=0) Z-Wave function call ‘org.openremote.protocol.zwave.model.commandclasses.CCMultiChannelV2FuncDecorator@17c24d7’.
DEBUG 2016-09-09 16:52:09,942 (Z-Wave): TX_Session_Layer : Executing Z-Wave function call ‘org.openremote.protocol.zwave.model.commandclasses.CCMultiChannelV2FuncDecorator@17c24d7’…
DEBUG 2016-09-09 16:52:09,943 (Z-Wave): TX_Session_Layer : Send (repeat count=1) Z-Wave function ‘ZW_SendData(NodeID=3, Payload=[0x25, 0x01, 0xFF], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x0D)’ request (callback ID=0x0D).
DEBUG 2016-09-09 16:52:09,943 (Z-Wave): TX_Frame_Layer : Send data frame [0x01, 0x0E, 0x00, 0x13, 0x03, 0x07, 0x60, 0x0D, 0x00, 0x01, 0x25, 0x01, 0xFF, 0x05, 0x0D, 0x59].
DEBUG 2016-09-09 16:52:09,959 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x06]
DEBUG 2016-09-09 16:52:09,960 (Z-Wave): RX_Frame_Layer : ACK -> Data frame [0x01, 0x0E, 0x00, 0x13, 0x03, 0x07, 0x60, 0x0D, 0x00, 0x01, 0x25, 0x01, 0xFF, 0x05, 0x0D, 0x59] transmission OK.
DEBUG 2016-09-09 16:52:09,960 (Z-Wave): RX_Session_Layer : ACK -> Z-Wave function ‘ZW_SendData(NodeID=3, Payload=[0x25, 0x01, 0xFF], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x0D)’ has been successfully sent - waiting 5,000 [ms] for response frame.
DEBUG 2016-09-09 16:52:09,963 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-09-09 16:52:09,964 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x04, 0x01, 0x13, 0x01, 0xE8]
DEBUG 2016-09-09 16:52:09,964 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] has been received.
DEBUG 2016-09-09 16:52:09,964 (Z-Wave): RX_Session_Layer : ‘ZW_SendData’ response [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] with status ‘RETURN_VALUE_TRUE’ received (callback ID=0x0D).
DEBUG 2016-09-09 16:52:09,965 (Z-Wave): RX_Session_Layer : Waiting 64,978 [ms] for ‘ZW_SendData’ callback frame (callback ID=0x0D).
DEBUG 2016-09-09 16:52:10,000 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-09-09 16:52:10,001 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x05, 0x00, 0x13, 0x0D, 0x00, 0xE4]
DEBUG 2016-09-09 16:52:10,001 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x05, 0x00, 0x13, 0x0D, 0x00, 0xE4] has been received.
DEBUG 2016-09-09 16:52:10,002 (Z-Wave): RX_Session_Layer : Callback [0x01, 0x05, 0x00, 0x13, 0x0D, 0x00, 0xE4] (callback ID=0x0D) with state ‘TRANSMIT_COMPLETE_OK’ received -> Z-Wave function ‘ZW_SendData(NodeID=3, Payload=[0x25, 0x01, 0xFF], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x0D)’ successfully executed.
DEBUG 2016-09-09 16:52:10,003 (Z-Wave): CCSwitchBinary : Node ‘3:1’ : [COMMAND_CLASS_SWITCH_BINARY::SWITCH_BINARY_SET, Value=‘255’] succeeded.
DEBUG 2016-09-09 16:52:12,778 (Z-Wave): Command_Builder : Building Z-Wave command
DEBUG 2016-09-09 16:52:12,778 (Z-Wave): Command_Builder : Z-Wave command: nodeId = ‘3’, endPoint = ‘2’
DEBUG 2016-09-09 16:52:12,778 (Z-Wave): Command_Builder : Z-Wave command: command = ON
DEBUG 2016-09-09 16:52:12,778 (Z-Wave): Command_Builder : Z-Wave command: paramValue = null
DEBUG 2016-09-09 16:52:12,778 (Z-Wave): Command_Builder : Z-Wave command created successfully
DEBUG 2016-09-09 16:52:12,779 (Z-Wave): CCSwitchBinary : Node ‘3:2’ : [COMMAND_CLASS_SWITCH_BINARY::SWITCH_BINARY_SET, Value=‘255’]
DEBUG 2016-09-09 16:52:12,779 (Z-Wave): Controller_API : Dequeue (queue count=0) Z-Wave function call ‘org.openremote.protocol.zwave.model.commandclasses.CCMultiChannelV2FuncDecorator@1480115’.
DEBUG 2016-09-09 16:52:12,779 (Z-Wave): Controller_API : Enqueue (queue count=1) Z-Wave function call ‘org.openremote.protocol.zwave.model.commandclasses.CCMultiChannelV2FuncDecorator@1480115’.
DEBUG 2016-09-09 16:52:12,779 (Z-Wave): TX_Session_Layer : Executing Z-Wave function call ‘org.openremote.protocol.zwave.model.commandclasses.CCMultiChannelV2FuncDecorator@1480115’…
DEBUG 2016-09-09 16:52:12,780 (Z-Wave): TX_Session_Layer : Send (repeat count=1) Z-Wave function ‘ZW_SendData(NodeID=3, Payload=[0x25, 0x01, 0xFF], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x0E)’ request (callback ID=0x0E).
DEBUG 2016-09-09 16:52:12,781 (Z-Wave): TX_Frame_Layer : Send data frame [0x01, 0x0E, 0x00, 0x13, 0x03, 0x07, 0x60, 0x0D, 0x00, 0x02, 0x25, 0x01, 0xFF, 0x05, 0x0E, 0x59].
DEBUG 2016-09-09 16:52:12,797 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x06]
DEBUG 2016-09-09 16:52:12,798 (Z-Wave): RX_Frame_Layer : ACK -> Data frame [0x01, 0x0E, 0x00, 0x13, 0x03, 0x07, 0x60, 0x0D, 0x00, 0x02, 0x25, 0x01, 0xFF, 0x05, 0x0E, 0x59] transmission OK.
DEBUG 2016-09-09 16:52:12,798 (Z-Wave): RX_Session_Layer : ACK -> Z-Wave function ‘ZW_SendData(NodeID=3, Payload=[0x25, 0x01, 0xFF], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x0E)’ has been successfully sent - waiting 5,000 [ms] for response frame.
DEBUG 2016-09-09 16:52:12,800 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-09-09 16:52:12,801 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x04, 0x01, 0x13, 0x01, 0xE8]
DEBUG 2016-09-09 16:52:12,801 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] has been received.
DEBUG 2016-09-09 16:52:12,801 (Z-Wave): RX_Session_Layer : ‘ZW_SendData’ response [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] with status ‘RETURN_VALUE_TRUE’ received (callback ID=0x0E).
DEBUG 2016-09-09 16:52:12,802 (Z-Wave): RX_Session_Layer : Waiting 64,979 [ms] for ‘ZW_SendData’ callback frame (callback ID=0x0E).
DEBUG 2016-09-09 16:52:12,837 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-09-09 16:52:12,838 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x05, 0x00, 0x13, 0x0E, 0x00, 0xE7]
DEBUG 2016-09-09 16:52:12,838 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x05, 0x00, 0x13, 0x0E, 0x00, 0xE7] has been received.
DEBUG 2016-09-09 16:52:12,839 (Z-Wave): RX_Session_Layer : Callback [0x01, 0x05, 0x00, 0x13, 0x0E, 0x00, 0xE7] (callback ID=0x0E) with state ‘TRANSMIT_COMPLETE_OK’ received -> Z-Wave function ‘ZW_SendData(NodeID=3, Payload=[0x25, 0x01, 0xFF], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x0E)’ successfully executed.
DEBUG 2016-09-09 16:52:12,839 (Z-Wave): CCSwitchBinary : Node ‘3:2’ : [COMMAND_CLASS_SWITCH_BINARY::SWITCH_BINARY_SET, Value=‘255’] succeeded.
DEBUG 2016-09-09 16:52:19,596 (Z-Wave): Command_Builder : Building Z-Wave command
DEBUG 2016-09-09 16:52:19,596 (Z-Wave): Command_Builder : Z-Wave command: nodeId = ‘3’, endPoint = ‘1’
DEBUG 2016-09-09 16:52:19,596 (Z-Wave): Command_Builder : Z-Wave command: command = OFF
DEBUG 2016-09-09 16:52:19,597 (Z-Wave): Command_Builder : Z-Wave command: paramValue = null
DEBUG 2016-09-09 16:52:19,597 (Z-Wave): Command_Builder : Z-Wave command created successfully
DEBUG 2016-09-09 16:52:19,597 (Z-Wave): CCSwitchBinary : Node ‘3:1’ : [COMMAND_CLASS_SWITCH_BINARY::SWITCH_BINARY_SET, Value=‘0’]
DEBUG 2016-09-09 16:52:19,597 (Z-Wave): Controller_API : Enqueue (queue count=1) Z-Wave function call ‘org.openremote.protocol.zwave.model.commandclasses.CCMultiChannelV2FuncDecorator@77669e’.
DEBUG 2016-09-09 16:52:19,598 (Z-Wave): Controller_API : Dequeue (queue count=0) Z-Wave function call ‘org.openremote.protocol.zwave.model.commandclasses.CCMultiChannelV2FuncDecorator@77669e’.
DEBUG 2016-09-09 16:52:19,598 (Z-Wave): TX_Session_Layer : Executing Z-Wave function call ‘org.openremote.protocol.zwave.model.commandclasses.CCMultiChannelV2FuncDecorator@77669e’…
DEBUG 2016-09-09 16:52:19,598 (Z-Wave): TX_Session_Layer : Send (repeat count=1) Z-Wave function ‘ZW_SendData(NodeID=3, Payload=[0x25, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x0F)’ request (callback ID=0x0F).
DEBUG 2016-09-09 16:52:19,599 (Z-Wave): TX_Frame_Layer : Send data frame [0x01, 0x0E, 0x00, 0x13, 0x03, 0x07, 0x60, 0x0D, 0x00, 0x01, 0x25, 0x01, 0x00, 0x05, 0x0F, 0xA4].
DEBUG 2016-09-09 16:52:19,614 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x06]
DEBUG 2016-09-09 16:52:19,615 (Z-Wave): RX_Frame_Layer : ACK -> Data frame [0x01, 0x0E, 0x00, 0x13, 0x03, 0x07, 0x60, 0x0D, 0x00, 0x01, 0x25, 0x01, 0x00, 0x05, 0x0F, 0xA4] transmission OK.
DEBUG 2016-09-09 16:52:19,615 (Z-Wave): RX_Session_Layer : ACK -> Z-Wave function ‘ZW_SendData(NodeID=3, Payload=[0x25, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x0F)’ has been successfully sent - waiting 5,000 [ms] for response frame.
DEBUG 2016-09-09 16:52:19,617 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-09-09 16:52:19,618 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x04, 0x01, 0x13, 0x01, 0xE8]
DEBUG 2016-09-09 16:52:19,618 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] has been received.
DEBUG 2016-09-09 16:52:19,619 (Z-Wave): RX_Session_Layer : ‘ZW_SendData’ response [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] with status ‘RETURN_VALUE_TRUE’ received (callback ID=0x0F).
DEBUG 2016-09-09 16:52:19,619 (Z-Wave): RX_Session_Layer : Waiting 64,980 [ms] for ‘ZW_SendData’ callback frame (callback ID=0x0F).
DEBUG 2016-09-09 16:52:19,655 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-09-09 16:52:19,656 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x05, 0x00, 0x13, 0x0F, 0x00, 0xE6]
DEBUG 2016-09-09 16:52:19,656 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x05, 0x00, 0x13, 0x0F, 0x00, 0xE6] has been received.
DEBUG 2016-09-09 16:52:19,657 (Z-Wave): RX_Session_Layer : Callback [0x01, 0x05, 0x00, 0x13, 0x0F, 0x00, 0xE6] (callback ID=0x0F) with state ‘TRANSMIT_COMPLETE_OK’ received -> Z-Wave function ‘ZW_SendData(NodeID=3, Payload=[0x25, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x0F)’ successfully executed.
DEBUG 2016-09-09 16:52:19,657 (Z-Wave): CCSwitchBinary : Node ‘3:1’ : [COMMAND_CLASS_SWITCH_BINARY::SWITCH_BINARY_SET, Value=‘0’] succeeded.
DEBUG 2016-09-09 16:52:21,570 (Z-Wave): Command_Builder : Building Z-Wave command
DEBUG 2016-09-09 16:52:21,570 (Z-Wave): Command_Builder : Z-Wave command: nodeId = ‘3’, endPoint = ‘2’
DEBUG 2016-09-09 16:52:21,570 (Z-Wave): Command_Builder : Z-Wave command: command = OFF
DEBUG 2016-09-09 16:52:21,571 (Z-Wave): Command_Builder : Z-Wave command: paramValue = null
DEBUG 2016-09-09 16:52:21,571 (Z-Wave): Command_Builder : Z-Wave command created successfully
DEBUG 2016-09-09 16:52:21,571 (Z-Wave): CCSwitchBinary : Node ‘3:2’ : [COMMAND_CLASS_SWITCH_BINARY::SWITCH_BINARY_SET, Value=‘0’]
DEBUG 2016-09-09 16:52:21,571 (Z-Wave): Controller_API : Enqueue (queue count=1) Z-Wave function call ‘org.openremote.protocol.zwave.model.commandclasses.CCMultiChannelV2FuncDecorator@14508c4’.
DEBUG 2016-09-09 16:52:21,571 (Z-Wave): Controller_API : Dequeue (queue count=0) Z-Wave function call ‘org.openremote.protocol.zwave.model.commandclasses.CCMultiChannelV2FuncDecorator@14508c4’.
DEBUG 2016-09-09 16:52:21,572 (Z-Wave): TX_Session_Layer : Executing Z-Wave function call ‘org.openremote.protocol.zwave.model.commandclasses.CCMultiChannelV2FuncDecorator@14508c4’…
DEBUG 2016-09-09 16:52:21,572 (Z-Wave): TX_Session_Layer : Send (repeat count=1) Z-Wave function ‘ZW_SendData(NodeID=3, Payload=[0x25, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x10)’ request (callback ID=0x10).
DEBUG 2016-09-09 16:52:21,573 (Z-Wave): TX_Frame_Layer : Send data frame [0x01, 0x0E, 0x00, 0x13, 0x03, 0x07, 0x60, 0x0D, 0x00, 0x02, 0x25, 0x01, 0x00, 0x05, 0x10, 0xB8].
DEBUG 2016-09-09 16:52:21,589 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x06]
DEBUG 2016-09-09 16:52:21,589 (Z-Wave): RX_Frame_Layer : ACK -> Data frame [0x01, 0x0E, 0x00, 0x13, 0x03, 0x07, 0x60, 0x0D, 0x00, 0x02, 0x25, 0x01, 0x00, 0x05, 0x10, 0xB8] transmission OK.
DEBUG 2016-09-09 16:52:21,590 (Z-Wave): RX_Session_Layer : ACK -> Z-Wave function ‘ZW_SendData(NodeID=3, Payload=[0x25, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x10)’ has been successfully sent - waiting 5,000 [ms] for response frame.
DEBUG 2016-09-09 16:52:21,592 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-09-09 16:52:21,592 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x04, 0x01, 0x13, 0x01, 0xE8]
DEBUG 2016-09-09 16:52:21,592 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] has been received.
DEBUG 2016-09-09 16:52:21,593 (Z-Wave): RX_Session_Layer : ‘ZW_SendData’ response [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] with status ‘RETURN_VALUE_TRUE’ received (callback ID=0x10).
DEBUG 2016-09-09 16:52:21,593 (Z-Wave): RX_Session_Layer : Waiting 64,979 [ms] for ‘ZW_SendData’ callback frame (callback ID=0x10).
DEBUG 2016-09-09 16:52:21,629 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-09-09 16:52:21,629 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x05, 0x00, 0x13, 0x10, 0x00, 0xF9]
DEBUG 2016-09-09 16:52:21,630 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x05, 0x00, 0x13, 0x10, 0x00, 0xF9] has been received.
DEBUG 2016-09-09 16:52:21,630 (Z-Wave): RX_Session_Layer : Callback [0x01, 0x05, 0x00, 0x13, 0x10, 0x00, 0xF9] (callback ID=0x10) with state ‘TRANSMIT_COMPLETE_OK’ received -> Z-Wave function ‘ZW_SendData(NodeID=3, Payload=[0x25, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x10)’ successfully executed.
DEBUG 2016-09-09 16:52:21,630 (Z-Wave): CCSwitchBinary : Node ‘3:2’ : [COMMAND_CLASS_SWITCH_BINARY::SWITCH_BINARY_SET, Value=‘0’] succeeded.
DEBUG 2016-09-09 16:52:22,151 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-09-09 16:52:22,151 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x0C, 0x00, 0x04, 0x00, 0x07, 0x06, 0x31, 0x05, 0x03, 0x0A, 0x00, 0x0D, 0xC6]
DEBUG 2016-09-09 16:52:22,152 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x0C, 0x00, 0x04, 0x00, 0x07, 0x06, 0x31, 0x05, 0x03, 0x0A, 0x00, 0x0D, 0xC6] has been received.
DEBUG 2016-09-09 16:52:22,152 (Z-Wave): RX_Session_Layer : Node ‘7’ : [APP_CMD_HANDLER_FRAME : NodeID=‘7’, Status=[RECEIVE_STATUS_TYPE_SINGLE], CommandClass=‘COMMAND_CLASS_SENSOR_MULTILEVEL’, Command=‘0x05’, Parameters: [0x03, 0x0A, 0x00, 0x0D]]
DEBUG 2016-09-09 16:52:22,153 (Z-Wave): CCMultiLevelSensor : Node ‘7:0’ : [COMMAND_CLASS_SENSOR_MULTILEVEL::SENSOR_MULTILEVEL_REPORT, Value=‘13’, Type=‘LUMINANCE’, Scale=‘LUMINANCE_SCALE_LUX’].
DEBUG 2016-09-09 16:52:24,484 (Z-Wave): Command_Builder : Building Z-Wave command
DEBUG 2016-09-09 16:52:24,484 (Z-Wave): Command_Builder : Z-Wave command: nodeId = ‘2’, endPoint = ‘1’
DEBUG 2016-09-09 16:52:24,484 (Z-Wave): Command_Builder : Z-Wave command: command = ON
DEBUG 2016-09-09 16:52:24,484 (Z-Wave): Command_Builder : Z-Wave command: paramValue = null
DEBUG 2016-09-09 16:52:24,484 (Z-Wave): Command_Builder : Z-Wave command created successfully
DEBUG 2016-09-09 16:52:24,485 (Z-Wave): CCMultiLevelSwitch : Node ‘2:0’ : [COMMAND_CLASS_SWITCH_MULTILEVEL::SWITCH_MULTILEVEL_SET, Value=‘255’]
DEBUG 2016-09-09 16:52:24,486 (Z-Wave): Controller_API : Enqueue (queue count=1) Z-Wave function call ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0xFF], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’.
DEBUG 2016-09-09 16:52:24,486 (Z-Wave): Controller_API : Dequeue (queue count=0) Z-Wave function call ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0xFF], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’.
DEBUG 2016-09-09 16:52:24,486 (Z-Wave): TX_Session_Layer : Executing Z-Wave function call ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0xFF], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’…
DEBUG 2016-09-09 16:52:24,487 (Z-Wave): TX_Session_Layer : Send (repeat count=1) Z-Wave function ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0xFF], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x11)’ request (callback ID=0x11).
DEBUG 2016-09-09 16:52:24,487 (Z-Wave): TX_Frame_Layer : Send data frame [0x01, 0x0A, 0x00, 0x13, 0x02, 0x03, 0x26, 0x01, 0xFF, 0x05, 0x11, 0x2B].
DEBUG 2016-09-09 16:52:24,499 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x06]
DEBUG 2016-09-09 16:52:24,499 (Z-Wave): RX_Frame_Layer : ACK -> Data frame [0x01, 0x0A, 0x00, 0x13, 0x02, 0x03, 0x26, 0x01, 0xFF, 0x05, 0x11, 0x2B] transmission OK.
DEBUG 2016-09-09 16:52:24,500 (Z-Wave): RX_Session_Layer : ACK -> Z-Wave function ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0xFF], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x11)’ has been successfully sent - waiting 5,000 [ms] for response frame.
DEBUG 2016-09-09 16:52:24,503 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-09-09 16:52:24,503 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x04, 0x01, 0x13, 0x01, 0xE8]
DEBUG 2016-09-09 16:52:24,504 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] has been received.
DEBUG 2016-09-09 16:52:24,504 (Z-Wave): RX_Session_Layer : ‘ZW_SendData’ response [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] with status ‘RETURN_VALUE_TRUE’ received (callback ID=0x11).
DEBUG 2016-09-09 16:52:24,504 (Z-Wave): RX_Session_Layer : Waiting 64,983 [ms] for ‘ZW_SendData’ callback frame (callback ID=0x11).
DEBUG 2016-09-09 16:52:24,515 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-09-09 16:52:24,515 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x05, 0x00, 0x13, 0x11, 0x00, 0xF8]
DEBUG 2016-09-09 16:52:24,516 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x05, 0x00, 0x13, 0x11, 0x00, 0xF8] has been received.
DEBUG 2016-09-09 16:52:24,516 (Z-Wave): RX_Session_Layer : Callback [0x01, 0x05, 0x00, 0x13, 0x11, 0x00, 0xF8] (callback ID=0x11) with state ‘TRANSMIT_COMPLETE_OK’ received -> Z-Wave function ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0xFF], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x11)’ successfully executed.
DEBUG 2016-09-09 16:52:24,517 (Z-Wave): CCMultiLevelSwitch : Node ‘2:0’ : [COMMAND_CLASS_SWITCH_MULTILEVEL::SWITCH_MULTILEVEL_SET, Value=‘255’] succeeded
DEBUG 2016-09-09 16:52:29,724 (Z-Wave): Command_Builder : Building Z-Wave command
DEBUG 2016-09-09 16:52:29,724 (Z-Wave): Command_Builder : Z-Wave command: nodeId = ‘2’, endPoint = ‘1’
DEBUG 2016-09-09 16:52:29,724 (Z-Wave): Command_Builder : Z-Wave command: command = ON
DEBUG 2016-09-09 16:52:29,724 (Z-Wave): Command_Builder : Z-Wave command: paramValue = null
DEBUG 2016-09-09 16:52:29,725 (Z-Wave): Command_Builder : Z-Wave command created successfully
DEBUG 2016-09-09 16:52:29,725 (Z-Wave): CCMultiLevelSwitch : Node ‘2:0’ : [COMMAND_CLASS_SWITCH_MULTILEVEL::SWITCH_MULTILEVEL_SET, Value=‘255’]
DEBUG 2016-09-09 16:52:29,726 (Z-Wave): Controller_API : Enqueue (queue count=1) Z-Wave function call ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0xFF], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’.
DEBUG 2016-09-09 16:52:29,726 (Z-Wave): Controller_API : Dequeue (queue count=0) Z-Wave function call ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0xFF], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’.
DEBUG 2016-09-09 16:52:29,726 (Z-Wave): TX_Session_Layer : Executing Z-Wave function call ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0xFF], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’…
DEBUG 2016-09-09 16:52:29,727 (Z-Wave): TX_Session_Layer : Send (repeat count=1) Z-Wave function ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0xFF], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x12)’ request (callback ID=0x12).
DEBUG 2016-09-09 16:52:29,727 (Z-Wave): TX_Frame_Layer : Send data frame [0x01, 0x0A, 0x00, 0x13, 0x02, 0x03, 0x26, 0x01, 0xFF, 0x05, 0x12, 0x28].
DEBUG 2016-09-09 16:52:29,739 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x06]
DEBUG 2016-09-09 16:52:29,739 (Z-Wave): RX_Frame_Layer : ACK -> Data frame [0x01, 0x0A, 0x00, 0x13, 0x02, 0x03, 0x26, 0x01, 0xFF, 0x05, 0x12, 0x28] transmission OK.
DEBUG 2016-09-09 16:52:29,740 (Z-Wave): RX_Session_Layer : ACK -> Z-Wave function ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0xFF], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x12)’ has been successfully sent - waiting 5,000 [ms] for response frame.
DEBUG 2016-09-09 16:52:29,743 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-09-09 16:52:29,743 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x04, 0x01, 0x13, 0x01, 0xE8]
DEBUG 2016-09-09 16:52:29,744 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] has been received.
DEBUG 2016-09-09 16:52:29,744 (Z-Wave): RX_Session_Layer : ‘ZW_SendData’ response [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] with status ‘RETURN_VALUE_TRUE’ received (callback ID=0x12).
DEBUG 2016-09-09 16:52:29,744 (Z-Wave): RX_Session_Layer : Waiting 64,983 [ms] for ‘ZW_SendData’ callback frame (callback ID=0x12).
DEBUG 2016-09-09 16:52:29,755 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-09-09 16:52:29,755 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x05, 0x00, 0x13, 0x12, 0x00, 0xFB]
DEBUG 2016-09-09 16:52:29,756 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x05, 0x00, 0x13, 0x12, 0x00, 0xFB] has been received.
DEBUG 2016-09-09 16:52:29,756 (Z-Wave): RX_Session_Layer : Callback [0x01, 0x05, 0x00, 0x13, 0x12, 0x00, 0xFB] (callback ID=0x12) with state ‘TRANSMIT_COMPLETE_OK’ received -> Z-Wave function ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0xFF], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x12)’ successfully executed.
DEBUG 2016-09-09 16:52:29,757 (Z-Wave): CCMultiLevelSwitch : Node ‘2:0’ : [COMMAND_CLASS_SWITCH_MULTILEVEL::SWITCH_MULTILEVEL_SET, Value=‘255’] succeeded
DEBUG 2016-09-09 16:52:32,140 (Z-Wave): Command_Builder : Building Z-Wave command
DEBUG 2016-09-09 16:52:32,140 (Z-Wave): Command_Builder : Z-Wave command: nodeId = ‘2’, endPoint = ‘1’
DEBUG 2016-09-09 16:52:32,140 (Z-Wave): Command_Builder : Z-Wave command: command = DIM
DEBUG 2016-09-09 16:52:32,140 (Z-Wave): Command_Builder : Z-Wave command: paramValue = 100
DEBUG 2016-09-09 16:52:32,140 (Z-Wave): Command_Builder : Z-Wave command created successfully
DEBUG 2016-09-09 16:52:32,141 (Z-Wave): CCMultiLevelSwitch : Node ‘2:0’ : [COMMAND_CLASS_SWITCH_MULTILEVEL::SWITCH_MULTILEVEL_SET, Value=‘99’]
DEBUG 2016-09-09 16:52:32,141 (Z-Wave): Controller_API : Enqueue (queue count=1) Z-Wave function call ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0x63], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’.
DEBUG 2016-09-09 16:52:32,142 (Z-Wave): Controller_API : Dequeue (queue count=0) Z-Wave function call ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0x63], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’.
DEBUG 2016-09-09 16:52:32,142 (Z-Wave): TX_Session_Layer : Executing Z-Wave function call ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0x63], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’…
DEBUG 2016-09-09 16:52:32,143 (Z-Wave): TX_Session_Layer : Send (repeat count=1) Z-Wave function ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0x63], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x13)’ request (callback ID=0x13).
DEBUG 2016-09-09 16:52:32,143 (Z-Wave): TX_Frame_Layer : Send data frame [0x01, 0x0A, 0x00, 0x13, 0x02, 0x03, 0x26, 0x01, 0x63, 0x05, 0x13, 0xB5].
DEBUG 2016-09-09 16:52:32,155 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x06]
DEBUG 2016-09-09 16:52:32,155 (Z-Wave): RX_Frame_Layer : ACK -> Data frame [0x01, 0x0A, 0x00, 0x13, 0x02, 0x03, 0x26, 0x01, 0x63, 0x05, 0x13, 0xB5] transmission OK.
DEBUG 2016-09-09 16:52:32,156 (Z-Wave): RX_Session_Layer : ACK -> Z-Wave function ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0x63], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x13)’ has been successfully sent - waiting 5,000 [ms] for response frame.
DEBUG 2016-09-09 16:52:32,159 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-09-09 16:52:32,159 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x04, 0x01, 0x13, 0x01, 0xE8]
DEBUG 2016-09-09 16:52:32,160 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] has been received.
DEBUG 2016-09-09 16:52:32,160 (Z-Wave): RX_Session_Layer : ‘ZW_SendData’ response [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] with status ‘RETURN_VALUE_TRUE’ received (callback ID=0x13).
DEBUG 2016-09-09 16:52:32,160 (Z-Wave): RX_Session_Layer : Waiting 64,982 [ms] for ‘ZW_SendData’ callback frame (callback ID=0x13).
DEBUG 2016-09-09 16:52:32,171 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-09-09 16:52:32,171 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x05, 0x00, 0x13, 0x13, 0x00, 0xFA]
DEBUG 2016-09-09 16:52:32,172 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x05, 0x00, 0x13, 0x13, 0x00, 0xFA] has been received.
DEBUG 2016-09-09 16:52:32,172 (Z-Wave): RX_Session_Layer : Callback [0x01, 0x05, 0x00, 0x13, 0x13, 0x00, 0xFA] (callback ID=0x13) with state ‘TRANSMIT_COMPLETE_OK’ received -> Z-Wave function ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0x63], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x13)’ successfully executed.
DEBUG 2016-09-09 16:52:32,173 (Z-Wave): CCMultiLevelSwitch : Node ‘2:0’ : [COMMAND_CLASS_SWITCH_MULTILEVEL::SWITCH_MULTILEVEL_SET, Value=‘99’] succeeded
DEBUG 2016-09-09 16:52:36,329 (Z-Wave): Command_Builder : Building Z-Wave command
DEBUG 2016-09-09 16:52:36,330 (Z-Wave): Command_Builder : Z-Wave command: nodeId = ‘2’, endPoint = ‘1’
DEBUG 2016-09-09 16:52:36,330 (Z-Wave): Command_Builder : Z-Wave command: command = DIM
DEBUG 2016-09-09 16:52:36,330 (Z-Wave): Command_Builder : Z-Wave command: paramValue = 0
DEBUG 2016-09-09 16:52:36,330 (Z-Wave): Command_Builder : Z-Wave command created successfully
DEBUG 2016-09-09 16:52:36,331 (Z-Wave): CCMultiLevelSwitch : Node ‘2:0’ : [COMMAND_CLASS_SWITCH_MULTILEVEL::SWITCH_MULTILEVEL_SET, Value=‘0’]
DEBUG 2016-09-09 16:52:36,331 (Z-Wave): Controller_API : Enqueue (queue count=1) Z-Wave function call ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’.
DEBUG 2016-09-09 16:52:36,331 (Z-Wave): Controller_API : Dequeue (queue count=0) Z-Wave function call ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’.
DEBUG 2016-09-09 16:52:36,332 (Z-Wave): TX_Session_Layer : Executing Z-Wave function call ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’…
DEBUG 2016-09-09 16:52:36,332 (Z-Wave): TX_Session_Layer : Send (repeat count=1) Z-Wave function ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x14)’ request (callback ID=0x14).
DEBUG 2016-09-09 16:52:36,332 (Z-Wave): TX_Frame_Layer : Send data frame [0x01, 0x0A, 0x00, 0x13, 0x02, 0x03, 0x26, 0x01, 0x00, 0x05, 0x14, 0xD1].
DEBUG 2016-09-09 16:52:36,344 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x06]
DEBUG 2016-09-09 16:52:36,344 (Z-Wave): RX_Frame_Layer : ACK -> Data frame [0x01, 0x0A, 0x00, 0x13, 0x02, 0x03, 0x26, 0x01, 0x00, 0x05, 0x14, 0xD1] transmission OK.
DEBUG 2016-09-09 16:52:36,345 (Z-Wave): RX_Session_Layer : ACK -> Z-Wave function ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x14)’ has been successfully sent - waiting 5,000 [ms] for response frame.
DEBUG 2016-09-09 16:52:36,348 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-09-09 16:52:36,348 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x04, 0x01, 0x13, 0x01, 0xE8]
DEBUG 2016-09-09 16:52:36,349 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] has been received.
DEBUG 2016-09-09 16:52:36,349 (Z-Wave): RX_Session_Layer : ‘ZW_SendData’ response [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] with status ‘RETURN_VALUE_TRUE’ received (callback ID=0x14).
DEBUG 2016-09-09 16:52:36,349 (Z-Wave): RX_Session_Layer : Waiting 64,983 [ms] for ‘ZW_SendData’ callback frame (callback ID=0x14).
DEBUG 2016-09-09 16:52:36,360 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-09-09 16:52:36,360 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x05, 0x00, 0x13, 0x14, 0x00, 0xFD]
DEBUG 2016-09-09 16:52:36,361 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x05, 0x00, 0x13, 0x14, 0x00, 0xFD] has been received.
DEBUG 2016-09-09 16:52:36,361 (Z-Wave): RX_Session_Layer : Callback [0x01, 0x05, 0x00, 0x13, 0x14, 0x00, 0xFD] (callback ID=0x14) with state ‘TRANSMIT_COMPLETE_OK’ received -> Z-Wave function ‘ZW_SendData(NodeID=2, Payload=[0x26, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x14)’ successfully executed.
DEBUG 2016-09-09 16:52:36,362 (Z-Wave): CCMultiLevelSwitch : Node ‘2:0’ : [COMMAND_CLASS_SWITCH_MULTILEVEL::SWITCH_MULTILEVEL_SET, Value=‘0’] succeeded
How to get a normal job dimmer? In the Controller version 2.1.1, this dimer worked perfectly - and as a switch, and as a slider.
node2.xml (2.25 KB)
node3.xml (2.96 KB)
