Hi all,
I want to add a volume slider for the Denon receiver to my panel.
What I already created is:
a set volume command
a get volume status command
a volume sensor using the get status command
a volume slider using the set volume command
The problem: when starting the panel the volume level is shown correctly and when changing volume level with original remote control the slider is updated correctly.
But when I want to change the volume level with the slider nothing happens.
The set volume command is a HTTP-command:
http://192.168.1.6/goform/formiPhoneAppVolume.xml?1+${param} Method: GET
I hope someone can help me.
Thanks in advance
Dieter
