Problems with User Management
I am experiencing several issues with user management in OpenRemote (on version 1.2.1, 1.2.2 and 1.2.3). These problems persist across multiple tests on different browsers and systems, including Mac (Intel & Apple Silicon) and Linux Debian.
The key issues I encountered are:
  1. Blank Screen After Login:
  • Users created through the OpenRemote Manager are unable to log in properly.
  • After entering their credentials, they are redirected to a blank page instead of the dashboard.
  • The admin user (default) does not experience this issue, only newly created users.
  1. User Creation Form Resets Fields:
  • When filling out the user creation form in OpenRemote Manager, some fields (such as username and email) get randomly reset before submission.
  • This forces the user to manually re-enter the information multiple times.
  1. User Creation Fails or is Incomplete:
  • In many cases, user creation fails without a clear error message.
  • When the user is successfully created, they often lack the roles and permissions that were set during the creation process.
  • This forces manual intervention in Keycloak to correct the missing roles.
I have tried multiple debugging steps:
  • Testing on different browsers (Chrome, Firefox, Safari).
  • Running OpenRemote on different machines (Mac Intel, Apple Silicon, and Linux Debian).
  • Ensuring that the Keycloak realm and roles are correctly configured.
  • Checking logs for errors related to user authentication and permissions.
I am unsure whether these issues are due to a misconfiguration on my part or if they are known bugs. Below is the docker-compose.yml file I am using for my deployment.
Docker Compose Configuration
(Email and domain information anonymized for privacy)
proxy-data:
manager-data:
postgresql-data:
services:
proxy:
restart: always
depends_on:
manager:
condition: service_healthy
ports:
- "80:80"
- "443:443"
- "8883:8883"
- "127.0.0.1:8404:8404"
- proxy-data:/deployment
- /etc/letsencrypt:/etc/letsencrypt
LE_EMAIL: [REDACTED]
DOMAINNAME: [REDACTED]
DOMAINNAMES: [REDACTED]
postgresql:
restart: always
shm_size: 128mb
- manager-data:/storage
keycloak:
restart: always
depends_on:
postgresql:
- ./deployment:/deployment
KC_HOSTNAME: [REDACTED]
KC_HOSTNAME_PORT: -1
KC_THEME: openremote
manager:
restart: always
image: openremote/manager:1.2.1
depends_on:
keycloak:
ports:
- "127.0.0.1:8405:8405"
OR_SETUP_TYPE:
OR_ADMIN_PASSWORD:
OR_SETUP_RUN_ON_RESTART:
OR_EMAIL_HOST:
OR_EMAIL_USER:
OR_EMAIL_PASSWORD:
OR_EMAIL_X_HEADERS:
OR_EMAIL_FROM:
OR_EMAIL_ADMIN:
OR_HOSTNAME: [REDACTED]
OR_ADDITIONAL_HOSTNAMES:
OR_SSL_PORT: 443
- ./deployment/keycloak/themes:/opt/keycloak/themes
Expected Behavior
  • Users should be able to log in successfully without encountering a blank page.
  • The user creation form should retain all field values until submission.
  • Users should be created with the correct roles and permissions as configured in OpenRemote Manager.
Actual Behavior
  • Users see a blank screen after logging in.
  • The user creation form resets fields, forcing repeated input.
  • Users lack roles and permissions after creation.
Questions
  • Are these known issues with OpenRemote from 1.2.1 to 1.2.3?
  • Is there something wrong with my docker-compose.yml configuration?
  • Could these issues be related to Keycloak misconfigurations?
Any help or guidance would be appreciated. Thanks in advance!
Issues appeared to be fixed / not reproduced with version 1.2.4
For more information, see Problems with User Management · Issue #1647 · openremote/openremote
