Hi all,
I’m new to openremote and I’m trying to publish a simple boolean value via MQTT.
I followed the tutorial “Connect your MQTT Client” and added a simple on/off sensor using the Thing asset type.
I can connect to my openremote setup using MQTTX and publish the value.
The value in the attribute is not updated however.
The response I get is:
Topic: master/client123/writeattributevalue/bel/41c4ZbpuOkejGhptk7Aaa7QoS: 0
true
I also tried 1 as value.
The attribute configuration is:
I also connected the attribute to the service user.
The service user is a non-restricted user with read and write access.
Can someone please help me with getting this to work?
Thanks in advance,
