I have added a consoleappconfig file as per the wiki but still get the error above. Did I create it in the correct folder? Is the file name correct? It should be the technical name of the realm, right?
I couldn’t manage to use push notifications with the default app, I think you need those instructions but maybe I’m wrong, let’s wait for someone else’s comment because I’m interested too
Hi, the ability to use push notifications with the default OR app (in the stores) unfortunately only works with openremote hosted environments as the FCM token in the default app corresponds. If you want to make it work, you would indeed have to build the apps yourself.
