From what I’ve read in the documentation, the Gateway tunnelling function can only be performed using AWS ROUTE 53 DNS.
If my central instance is in another cloud, it would not be possible to use this function, is that correct?
Thank you very much.
If you’re hosting your central instance on another cloud and cannot use AWS Route 53 for the Gateway tunneling function, here are alternative approaches:
*.yourdomain.com) with your cloud provider’s DNS or another public DNS service./etc/hosts (not scalable and lacks HTTPS support).Sish, which the Gateway function uses under the hood, is flexible with DNS systems as long as subdomains resolve to the server’s IP. You’re not limited to AWS Route 53.
If DNS setup is impractical, consider using a VPN tunnel:
10.8.0.1:8080), removing the need for public DNS or subdomains.FYI: No, the gateway tunneling functionality is not specific to AWS.
@Rich anything to add? Since the documentation is not very clear on this ![]()
Route53 is definitely an AWS-specific term, so setting AWS_ROUTE53_ROLE makes perfect sense. Tunneling, however, shouldn’t be tied to any specific cloud provider. That said, the implementation described in the docs seems to be tightly integrated with AWS.
AWS_ROUTE53_ROLE is not coupled to tunnelling specifically but is used by the proxy container to allow auto wildcard cert generation with LetsEncrypt which requires adding txt records to DNS.
Wildcard cert is needed for gateway as SISH uses subdomains for routing.
It is perfectly fine to provide your own wildcard cert (and we have customers that do); the AWS mechanism is there primarily for our benefit but others can use it and/or the proxy container can be enhanced to add additional plugins rather than just the certbot-dns-route53 plugin.
Thank you very much for everyone’s prompt response. My intention was to test the OR Tunneling features. I use Cloudflare as my DNS server. I’ll do some research on how to implement it and let you know the result.
As Michal suggested in point 2, I currently have Wireguard implemented and thus I can remotely access the EDGE instances. It works very well and I have no problems.
I simply wanted to look for an alternative to a VPN.
Regards.
