Could anybody signpost me on this? I think the data-format(s) should be very straightforward but I can’t find any documentation on them anywhere? Thanks!
The payload should be a JSON (object) of the attribute value.
For example, as you are showing with the numbers; you can simply send the raw value.
With sime complex objects, it should be a JSON object,
For context; the MQTT API, and its publish topic is documented here.
In case of IP addresses, I believe you can simply use a string.
For locations, I believe it would be a string of coordinates, right? Like in the UI?
(not entirely sure about this)
Yes thanks for the link. It would be super helpful to have an example of a good JSON payload (or other) for both IP Address and GEO JSON as I’ve tried a number of permutations with no success
I’ve tried sending a string payload for IP address e.g. “192.168.1.1” and the attribute just goes “blank”
There’s still something very odd about IP address. From the errors in the logs it looks like if I send a string it errors as it wants to parse JSON But if I send JSON then it errors as it wants to parse a string
2024-07-25 23:21:11.074 INFO [Thread-29 (ActiveMQ-clie..ads)] te.model.util.ValueUtil.MODEL_AND_VALUES : Failed to parse JSON string: 192.168.1.1
com.fasterxml.jackson.core.JsonParseException: Unexpected character ('.' (code 46)): Expected space separating root-level values
at [Source: REDACTED (`StreamReadFeature.INCLUDE_SOURCE_IN_LOCATION` disabled); line: 1, column: 9]
at com.fasterxml.jackson.core.JsonParser._constructError(JsonParser.java:2481)
at com.fasterxml.jackson.core.base.ParserMinimalBase._reportError(ParserMinimalBase.java:752)
at com.fasterxml.jackson.core.base.ParserMinimalBase._reportUnexpectedChar(ParserMinimalBase.java:676)
at com.fasterxml.jackson.core.base.ParserMinimalBase._reportMissingRootWS(ParserMinimalBase.java:724)
at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._verifyRootSpace(ReaderBasedJsonParser.java:1834)
at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._parseFloat(ReaderBasedJsonParser.java:1494)
at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._parseUnsignedNumber(ReaderBasedJsonParser.java:1422)
at com.fasterxml.jackson.core.json.ReaderBasedJsonParser.nextToken(ReaderBasedJsonParser.java:809)
at com.fasterxml.jackson.databind.ObjectMapper._initForReading(ObjectMapper.java:4986)
at com.fasterxml.jackson.databind.ObjectMapper._readMapAndClose(ObjectMapper.java:4892)
at com.fasterxml.jackson.databind.ObjectMapper.readValue(ObjectMapper.java:3846)
at com.fasterxml.jackson.databind.ObjectMapper.readValue(ObjectMapper.java:3814)
at org.openremote.model.util.ValueUtil.parse(ValueUtil.java:205)
at org.openremote.manager.mqtt.DefaultMQTTHandler.onPublish(DefaultMQTTHandler.java:427)
at org.openremote.manager.mqtt.MQTTHandler.lambda$addPublishConsumer$0(MQTTHandler.java:132)
at org.apache.activemq.artemis.core.client.impl.ClientConsumerImpl.callOnMessage(ClientConsumerImpl.java:982)
at org.apache.activemq.artemis.core.client.impl.ClientConsumerImpl$Runner.run(ClientConsumerImpl.java:1134)
at org.apache.activemq.artemis.utils.actors.OrderedExecutor.doTask(OrderedExecutor.java:57)
at org.apache.activemq.artemis.utils.actors.OrderedExecutor.doTask(OrderedExecutor.java:32)
at org.apache.activemq.artemis.utils.actors.ProcessorBase.executePendingTasks(ProcessorBase.java:68)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
at org.apache.activemq.artemis.utils.ActiveMQThreadFactory$1.run(ActiveMQThreadFactory.java:118)
2024-07-25 23:14:48.976 WARNING [Pool-AttributeEventProce..1-16] ote.manager.asset.AssetProcessingService : Error processing from DefaultMQTTHandler: AttributeEvent{timestamp=2024-07-25T21:14:48.968Z, ref=AttributeRef{id='43xLqosLx5plzmceavH0ym', name='ipaddress'}, valueType=java.util.LinkedHashMap} - INVALID_VALUE (Event processing failed unable to coerce value into the correct value type: realm=null, attribute=AttributeRef{id='43xLqosLx5plzmceavH0ym', name='ipaddress'}, event value type=class java.util.LinkedHashMap, attribute value type=class java.lang.String)
2024-07-25 23:14:49.966 INFO [Pool-AttributeEventProce..1-16] te.model.util.ValueUtil.MODEL_AND_VALUES : Failed to coerce value to requested type: input=class java.util.LinkedHashMap, output=class java.lang.String
java.lang.IllegalArgumentException: Cannot deserialize value of type `java.lang.String` from Object value (token `JsonToken.START_OBJECT`)
at [Source: UNKNOWN; byte offset: #UNKNOWN]
at com.fasterxml.jackson.databind.ObjectMapper._convert(ObjectMapper.java:4618)
at com.fasterxml.jackson.databind.ObjectMapper.convertValue(ObjectMapper.java:4549)
at org.openremote.model.util.ValueUtil.getValue(ValueUtil.java:358)
at org.openremote.model.util.ValueUtil.getValueCoerced(ValueUtil.java:385)
at org.openremote.manager.asset.AssetProcessingService.lambda$processAttributeEvent$15(AssetProcessingService.java:395)
at java.base/java.util.Optional.map(Optional.java:260)
at org.openremote.manager.asset.AssetProcessingService.lambda$processAttributeEvent$18(AssetProcessingService.java:393)
at org.openremote.container.persistence.PersistenceService.lambda$doTransaction$4(PersistenceService.java:416)
at org.openremote.container.persistence.PersistenceService.doReturningTransaction(PersistenceService.java:426)
at org.openremote.container.persistence.PersistenceService.doTransaction(PersistenceService.java:415)
at org.openremote.manager.asset.AssetProcessingService.processAttributeEvent(AssetProcessingService.java:380)
at org.openremote.manager.asset.AssetProcessingService.lambda$configure$11(AssetProcessingService.java:326)
at org.apache.camel.support.processor.DelegateSyncProcessor.process(DelegateSyncProcessor.java:65)
at org.apache.camel.processor.errorhandler.RedeliveryErrorHandler$RedeliveryTask.doRun(RedeliveryErrorHandler.java:824)
at org.apache.camel.processor.errorhandler.RedeliveryErrorHandler$RedeliveryTask.run(RedeliveryErrorHandler.java:732)
at org.apache.camel.impl.engine.DefaultReactiveExecutor$Worker.executeReactiveWork(DefaultReactiveExecutor.java:196)
at org.apache.camel.impl.engine.DefaultReactiveExecutor$Worker.schedule(DefaultReactiveExecutor.java:164)
at org.apache.camel.impl.engine.DefaultReactiveExecutor.scheduleMain(DefaultReactiveExecutor.java:59)
at org.apache.camel.processor.Pipeline.process(Pipeline.java:163)
at org.apache.camel.impl.engine.CamelInternalProcessor.process(CamelInternalProcessor.java:383)
at org.apache.camel.component.seda.SedaConsumer.sendToConsumers(SedaConsumer.java:267)
at org.apache.camel.component.seda.SedaConsumer.doRun(SedaConsumer.java:186)
at org.apache.camel.component.seda.SedaConsumer.run(SedaConsumer.java:129)
at java.base/java.lang.Thread.run(Thread.java:840)
Caused by: com.fasterxml.jackson.databind.exc.MismatchedInputException: Cannot deserialize value of type `java.lang.String` from Object value (token `JsonToken.START_OBJECT`)
at com.fasterxml.jackson.databind.exc.MismatchedInputException.from(MismatchedInputException.java:59)
at com.fasterxml.jackson.databind.DeserializationContext.reportInputMismatch(DeserializationContext.java:1767)
at com.fasterxml.jackson.databind.DeserializationContext.handleUnexpectedToken(DeserializationContext.java:1541)
at com.fasterxml.jackson.databind.DeserializationContext.handleUnexpectedToken(DeserializationContext.java:1446)
at com.fasterxml.jackson.databind.DeserializationContext.extractScalarFromObject(DeserializationContext.java:958)
at com.fasterxml.jackson.databind.deser.std.StdDeserializer._parseString(StdDeserializer.java:1424)
at com.fasterxml.jackson.databind.deser.std.StringDeserializer.deserialize(StringDeserializer.java:48)
at com.fasterxml.jackson.databind.deser.std.StringDeserializer.deserialize(StringDeserializer.java:11)
at com.fasterxml.jackson.databind.ObjectMapper._convert(ObjectMapper.java:4613)
... 25 more
2024-07-25 23:14:49.967 WARNING [Pool-AttributeEventProce..1-16] ote.manager.asset.AssetProcessingService : Error processing from DefaultMQTTHandler: AttributeEvent{timestamp=2024-07-25T21:14:49.965Z, ref=AttributeRef{id='43xLqosLx5plzmceavH0ym', name='ipaddress'}, valueType=java.util.LinkedHashMap} - INVALID_VALUE (Event processing failed unable to coerce value into the correct value type: realm=null, attribute=AttributeRef{id='43xLqosLx5plzmceavH0ym', name='ipaddress'}, event value type=class java.util.LinkedHashMap, attribute value type=class java.lang.String)
