Hi, I’m having issues running the same builds on Windows 8
Windows 8 64 bit
OpenRemoteControler 2.6.0 (Beta1) (https://github.com/openremote/Controller/releases/download/v2.6.0_beta/OpenRemote_Controller.zip)
Z-Wave 3.1.2 Beta1
Java 1.8
Aeon Labs Z-Stick Gen5
The node is successfully added but it never seems to finish initialization / inclusion and never creates the nodexx.xml file. Get java.exceptions which look to be related straight after it receives node info. Any ideas would be appreciated. I’ve tried several different machines / java versions.
ERROR [HTTP-Thread-4]: Failed to execute REST API call 'http://192.168.0.8:8688/
controller/rest/commands’ : Invalid URL format – expected format '/rest/devices
/{device_name}/commands?name={command_name}’, got ‘/rest/commandsnull’.
Jan 06, 2017 11:29:51 PM org.restlet.engine.connector.HttpClientHelper start
INFO: Starting the internal HTTP client
INFO 2017-01-06 23:30:02,804 : Inclusion_Manager : Node ‘19’ : Z-Wave
node has been successfully added to the SECURE Z-Wave network.
Jan 06, 2017 11:30:02 PM org.restlet.engine.connector.HttpClientHelper stop
INFO: Stopping the internal HTTP client
INFO 2017-01-06 23:30:02,851 : Controller : Z-Wave node info (
ID=19) : [[Device Classes : ‘BASIC_TYPE_ROUTING_SLAVE’,'GENERIC_TYPE_SWITCH_MULT
ILEVEL’,‘SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL’],[Capabilities : 'NODEINFO_CAPAB
ILITY_ROUTING’,‘NODEINFO_CAPABILITY_LISTENING’],[Security : 'NODEINFO_SECURITY_O
PTIONAL_FUNC_SUPPORT’]].
Exception in thread “pool-1-thread-5” java.lang.ClassCastException: org.openremo
te.protocol.zwave.model.commandclasses.CCMultiChannelV2FuncDecorator cannot be c
ast to org.openremote.protocol.zwave.port.function.ZWSendDataFunc
at org.openremote.protocol.zwave.model.commandclasses.CCSecurityFuncDeco
rator.(CCSecurityFuncDecorator.java:144)
at org.openremote.protocol.zwave.model.commandclasses.Context.decorateFu
nction(Context.java:322)
nction(Context.java:294)
at org.openremote.protocol.zwave.model.commandclasses.CCSecurity.enqueue
GetSupportedFunc(CCSecurity.java:1752)
at org.openremote.protocol.zwave.model.ZWNodeInitializer.nextSecureEndPo
int(ZWNodeInitializer.java:1573)
at org.openremote.protocol.zwave.model.ZWNodeInitializer.access$5000(ZWN
odeInitializer.java:36)
at org.openremote.protocol.zwave.model.ZWNodeInitializer$13.ccMultiChann
elV2GetCapabilityCallback(ZWNodeInitializer.java:1512)
at org.openremote.protocol.zwave.model.commandclasses.CCMultiChannelV2$G
etEndPointCapabilityFunc$1.run(CCMultiChannelV2.java:1152)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.
java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor
.java:617)
Jan 06, 2017 11:30:23 PM org.restlet.engine.connector.HttpClientHelper start
Jan 06, 2017 11:30:56 PM org.restlet.engine.connector.HttpClientHelper start
