I added the access_token to the Authorization section when configuring a Get request in Postman. The made the request below https://localhost/api/10038/realm
When I run this command I get an 401 Unauthorized with www-authenticate value saying Bearer realm=“10038”, error=“invalid_token”, error_description=“Token is not active”
Are you using the Postman OAuth 2.0 functionality in the Authorization tab? It will take care of getting the token and using it. Select the type and on the right side fill in the ‘Configure New Token’ form to get the token. You can then click to use the token in the dialog that appears. Now you will be correctly authorized (in my limited experience )
You need to go to “Authorization”, there you choose Type “OAuth 2.0” and fill out the required fields under “Configure New Token”: Grant Type (in my case “Client Credentials”), Access Token URL (https://localhost/auth/realms/10038/protocol/openid-connect/token), Client ID (Service User), Client Secret (generated password of Service User). Afterwards click “Get New Access Token”. It should say now something like completed, then press “Proceed” and “Use Token”. Afterwards everything should be ready to make a request.
Also the the info & health requests only work for about a minute before I have to refresh the tolken again.
I’m wondering if this is something to do with my installation. I’m working on Hyper-v Ubuntu 22.04 VM running on a Win 10 host. I could not get Docker Desktop to install correctly presumably due to lack of KVM (?). I therefore installed and ran Docker via apt.
Is anyone able to confirm or deny being able to run openremote on the setup I have or is Docker Desktop a must have?
If I try this one then its returns successfully. I guess there are some permission issues somewhere stopping the specific service user I set up accessing the first request. https://localhost/api/10038/realm/10038
I still have the issue of the access token timing out after 60 seconds and it not autmotaically requesting a new one however I’m assuming this can be addressed programatically if I automate the api requests.
