I added an attribute named “test” to my asset and connected it to my ESP32 via MQTT. But when I try to create a rule using when… then…, the “test” attribute doesn’t appear in the list of available attributes.
Hi Miryam
Try modifying the asset and add a configuration item to the attribute and check the "Rule State: box.
The attribute should then be selectable in the when/then rule.
Cheers
