Currently I’m trying to set up an OR on my webserver. On the server a nginx application runs and using the port 80. If I try to map the port 80 and 433 to 83 and 8083, it is possible to login to the OR web-interface. But it seems it does not work correctly. e.g. I can not add any device.
I use the docker-compose.yml from the getting starting guide. I set the port 80:80 to 83:80 at the .yml and set the OR_SSL_PORT to 8083. Also the hostname to my website subdomain. e.g. iot.example.com
Which settings I must setup to get an successfull running OR for the case, where the port 80 is still in use from an other application?
Best regards,
Thomas Enzinger
