Vicky
March 29, 2023, 8:42pm
#1
I am trying to setting up IDE for OpenRemote and run the manager but I get Build failed error I follow the documents for Setting up IDE document but i get the error.
I don’t know exactly how to do it.
Any idea how to fix this issue?
Thanks in advance.
ixxc
March 30, 2023, 1:43am
#2
Give more information about the error you got please
Vicky
March 30, 2023, 4:08am
#3
Hi ixxc,
I am new user so i am not able to shared my snip,
Error i get:
[+] Running 2/2
Container openremote-postgresql-1 Healthy 0.6s
Container openremote-keycloak-1 Running 0.0s
PS C:\Users\procu\Downloads\Procubed_OR-Environment_setup\openremote-master> ./gradlew clean installDist
Configure project :
File encryption plugin config found, configuring git pre commit hook and decrypt task dependency
FAILURE: Build failed with an exception.
Failed to notify project evaluation listener.
C:\Users\procu\Downloads\Procubed_OR-Environment_setup\openremote-master.git\hooks\pre-commit (The system cannot find the path specified)
Run with --stacktrace option to get the stack trace.
Run with --info or --debug option to get more log output.
Run with --scan to get full insights.
BUILD FAILED in 1s
apurba
March 30, 2023, 4:31am
#4
pls run below command in docker directory
docker-compose pull
docker-compose up / docker-compose -p openremote up
and share screenshot here
Vicky
March 30, 2023, 4:34am
#5
This command not run
PS C:\Users\procu\Downloads\Procubed_OR-Environment_setup\openremote-master> docker-compose pull
[+] Running 0/4
postgresql Error 10.6s
manager Error 10.6s
keycloak Error 10.6s
proxy Error 10.6s
Error response from daemon: Get “https://registry-1.docker.io/v2/ ”: net/http: TLS handshake timeout
apurba
March 30, 2023, 4:37am
#6
share yml file here
kindly share the path of docker compose file .
Vicky
March 30, 2023, 4:41am
#7
OpenRemote v3
Profile that runs the stack by default on https://localhost using a self-signed SSL certificate,
but optionally on https://$OR_HOSTNAME with an auto generated SSL certificate from Letsencrypt.
It is configured to use the AWS logging driver.
version: ‘2.4’
proxy-data:
manager-data:
postgresql-data:
services:
proxy:
restart: always
depends_on:
manager:
condition: service_healthy
ports:
- “80:80”
- “${OR_SSL_PORT:-443}:443”
- “8883:8883”
- proxy-data:/deployment
LE_EMAIL: ${OR_EMAIL_ADMIN:-}
#HAPROXY_CONFIG: ‘/data/proxy/haproxy.cfg’
postgresql:
restart: always
- manager-data:/storage
keycloak:
restart: always
depends_on:
postgresql:
- ./deployment:/deployment
KC_HOSTNAME_PORT: ${OR_SSL_PORT:–1}
manager:
privileged: true
restart: always
depends_on:
keycloak:
OR_SETUP_TYPE:
OR_ADMIN_PASSWORD:
OR_SETUP_RUN_ON_RESTART:
OR_EMAIL_HOST:
OR_EMAIL_USER:
OR_EMAIL_PASSWORD:
OR_EMAIL_X_HEADERS:
OR_EMAIL_FROM:
OR_EMAIL_ADMIN:
OR_FORECAST_SOLAR_API_KEY:
OR_OPEN_WEATHER_API_APP_ID:
apurba
March 30, 2023, 4:56am
#8
hi.
i think problem is in your yml file
make a folder name docker in desktop ----> keep yml file (which i share now ) —. open cmd in same directory
New folder.zip (1.1 KB)
and run the above command
Vicky
March 30, 2023, 5:01am
#9
hi,
Got Same error after change yml
[+] Running 0/4
manager Error 10.7s
postgresql Error 10.7s
proxy Error 10.7s
keycloak Error 10.7s
apurba
March 30, 2023, 5:11am
#10
hi,
join
google meet now
meet.google.com/vfw-kxez-dxa
and run
systemctl daemon-reload
systemctl restart docker
systemctl status docker
docker pull hello-world
