07/28/2022 12:51:48 INFO API DefaultMQTTHandler Subscription was not authorised for this user and topic: topic=master/mqttclient/attribute/subscribeAttribute/3OUTeS8lisOFZtI0kPxf7X, connection=MqttConnection{connectionTime=1659005498551, realm=‘master’, username=‘mqttuser’, clientId=‘mqttclient’, obsolete=‘false’}
07/28/2022 12:53:44 WARN ASSET Error processing from CLIENT - INSUFFICIENT_ACCESS: AttributeEvent{timestamp=Thu Jul 28 12:53:44 CEST 2022, attributeState=AttributeState{ref=AttributeRef{id=‘3OUTeS8lisOFZtI0kPxf7X’, name=‘writeAttribute’}, value=23, deleted=false}}
I have the same issue.
The clientId in the mqtt connection and subscriptions string are the same .
I set services user in OR with all privileges and chose “linked assets” selecting the propper asset.
2022-08-10 15:17:10.370 WARNING [nioEventLoopGroup-3-1 ] io.moquette.broker.Authorizator : Client does not have read permissions on the topic username: master:auremqtt, messageId: 32809, topic: master/mqtt-explorer-982c6064/attribute/subscribeAttribute/7Ik9DNCysQOVvgNltSXhb4
2022-08-10 15:17:39.289 INFO [nioEventLoopGroup-3-2 ] mote.manager.mqtt.DefaultMQTTHandler.API : Subscription was not authorised for this user and topic: topic=master/client123/attribute/subscribeAttribute/7Ik9DNCysQOVvgNltSXhb4, connection=MqttConnection{connectionTime=1660137430354, realm='master', username='auremqtt', clientId='client123', obsolete='false'}
2022-08-10 15:17:39.291 WARNING [nioEventLoopGroup-3-2 ] io.moquette.broker.Authorizator : Client does not have read permissions on the topic username: master:auremqtt, messageId: 33920, topic: master/client123/attribute/subscribeAttribute/7Ik9DNCysQOVvgNltSXhb4
Could you make sure you have the latest version of OpenRemote, redeploy, and create a new service user and test again with the new user. To rule out any outdated issues.
when doing so to make sure you are using the most recent commit set MANAGER_VERSION=develop
(or image: openremote/manager:${MANAGER_VERSION:-develop} in the docker file)
Develop contains all latest commits, including a fix for your issue. Latest (well not really latest as you can see ) is manually set and will be updated soon.
