Upon running npm run serve, it seems as though everything is able to run
> @openremote/custom@1.0.0 serve
> npx tsc -b --clean && npx shx rm -rf dist && npx orutil build && npx cross-env NODE_OPTIONS=--max_old_space_size=4096 webpack serve --mode development
Running gradlew modelBuild task in C:\Users\kaswe\CusOpenRemote ...
gradlew modelWatch finished! Status = 0
To customise the URL of the manager and/or keycloak use the managerUrl and/or keycloakUrl
environment arguments e.g:
npm run serve -- --env managerUrl=https://localhost
npm run serve -- --env keycloakUrl=https://localhost/auth
MANAGER URL: http://localhost:8080
KEYCLOAK URL: undefined
<i> [webpack-dev-server] Project is running at:
<i> [webpack-dev-server] Loopback: http://localhost:9000/
<i> [webpack-dev-server] On Your Network (IPv4): http://172.30.61.161:9000/
<i> [webpack-dev-server] Content not from webpack is served from 'src' directory
<i> [webpack-dev-server] 404s will fallback to '/custom/'
<i> [webpack-dev-middleware] wait until bundle finished: /
assets by path *.js 37.5 MiB
asset bundle.87bc707501a1b3e9b822.js 24 MiB [emitted] [immutable] (name: bundle)
asset 63b15fb6fc8f897b22a4bf72b7e8452a.js 3.34 MiB [emitted] [immutable] [from: ../../../node_modules/ace-builds/src-noconflict/worker-xquery.js] (auxiliary name: bundle)
asset 03371bf1d5cbb1eab58e3a0130d1e9c2.js 705 KiB [emitted] [immutable] [from: ../../../node_modules/ace-builds/src-noconflict/worker-javascript.js] (auxiliary name: bundle)
+ 423 assets
assets by path ../ 3.95 MiB
assets by path ../../../../openremote/ui/component/ 3.54 MiB 375 assets
assets by path ../../../../openremote/ui/app/manager/ 417 KiB 46 assets
assets by path ../lib/ 1.63 KiB 2 assets
assets by path modules/@webcomponents/webcomponentsjs/ 3.19 MiB 48 assets
assets by path locales/ 119 bytes
asset locales/en/app.json 76 bytes [emitted] [from: locales/en/app.json] [copied]
asset locales/nl/app.json 43 bytes [emitted] [from: locales/nl/app.json] [copied]
asset index.html 3.66 KiB [emitted]
orphan modules 21.4 KiB [orphan] 17 modules
runtime modules 2.54 KiB 10 modules
modules by path ../../../node_modules/ 8.08 MiB
javascript modules 7.3 MiB 1153 modules
asset modules 795 KiB 24 modules
json modules 3.07 KiB 2 modules
modules by path ../../../openremote/ui/ 922 KiB
modules by path ../../../openremote/ui/component/ 894 KiB 61 modules
modules by path ../../../openremote/ui/app/manager/lib/ 27.6 KiB
modules by path ../../../openremote/ui/app/manager/lib/*.js 3.27 KiB 2 modules
modules by path ../../../openremote/ui/app/manager/lib/pages/*.js 24.3 KiB 2 modules
modules by path ./ 4.19 KiB
./src/index.ts 2.4 KiB [built] [code generated]
./src/pages/page-custom.ts 1.77 KiB [built] [code generated]
./util.inspect (ignored) 15 bytes [built] [code generated]
webpack 5.72.0 compiled successfully in 31518 ms
<i> [webpack-dev-middleware] wait until bundle finished: /modules/@webcomponents/webcomponentsjs/custom-elements-es5-adapter.js
<i> [webpack-dev-middleware] wait until bundle finished: /modules/@webcomponents/webcomponentsjs/webcomponents-loader.js
assets by status 16.7 MiB [cached] 475 assets
assets by status 24 MiB [emitted]
asset bundle.16704a1e149b54dfa921.js 24 MiB [emitted] [immutable] (name: bundle)
cached modules 8.2 MiB [cached] 1207 modules
javascript modules 823 KiB
modules by path ../../../openremote/ui/component/ 795 KiB 53 modules
../../../openremote/ui/app/manager/lib/headers.js 2.94 KiB [built]
../../../openremote/ui/app/manager/lib/routes.js 341 bytes [built]
However, upon trying to access the URL itself, it seems as though none of the components are loaded.
Could I get some advice on what to look into to fix this issue? For reference, the way I set this up was using the custom-project template found on the github, followed by using the git submodule function within custom project.
Unsure if this will help, but here is my Inspector window
