I’ve been exploring OpenRemote for a few months and am far more familiar with it than I started but have still only scratched the surface. I’ve experimented with adding my customisation to a simple folder as per this video and forking the openremote repo but I can see the value in using the custom-project repo so that’s where I am now but I’m getting an error when serving the Manager UI as per this wiki page.
But I get an error and don’t know how to start
Here’s the steps I’ve taken;
Created a private respository (custom-project.git) using https://github.com/openremote/custom-project as template
Cloned custom-project.git onto windows machine at c:/git/custom-project
Prepared my environment as per https://github.com/openremote/openremote/wiki/Developer-Guide%3A-Preparing-the-environment
|--java --version (17.0.9)
|--git --version (2.43.0.windows.1)
|--node -v (v18.19.0)
|--yarn -v (1.22.21)
|--JAVA_HOME (C:\Program Files\Java\jdk-17)
Initialised openremote submodule
|--cd c:\git\custom-project
|--git submodule init
|--git submodule update --rebase --remote
Set up IntelliJ IDEA Community Edition 2023.2.5 as per https://github.com/openremote/openremote/wiki/Developer-Guide%3A-Setting-up-an-IDE
|--opened C:\git\custom-project\openremote folder as IntelliJ project
|--Set "Build and run using" and "Run test using" to "IntelliJ IDEA" within File->Settings->"Build,Execution,Deployment"->"Build Tools"->Gradle
|--Using IntelliJ terminal ran ./gradlew clean installDist
|--As I have used https://github.com/openremote/custom-project as a template all Application Run Configuration already have the openremote submodule set as the working directory
Run Docker container
|--docker-compose -p openremote -f profile/dev-testing.yml up --build -d
Run the "Demo Setup" run configuration within IntelliJ IDE
Served the manager UI
|--cd c:\git\custom-project\openremote\ui\app\manager
|--npm run serve
|--Error in c:\git\custom-project\openremote\ui\component\model\build.gradle line: 13 (Plugin [id: 'cz.habarta.typescript-generator'] was not found)
|--changed line 13 from "id 'cz.habarta.typescript-generator'" to "id 'cz.habarta.typescript-generator' version "$typescriptGeneratorVersion""
|--npm run serve
|--Error in c:\git\custom-project\openremote\ui\component\model\build.gradle line: 17 (A problem occurred evaluating project ':openremote:ui:component:model')
I can see that “c:\git\custom-project\openremote\model-util” exists and it contains a build.gradle file so I’m not sure why gradle can’t find it.
