Hi everyone,
I used to work the former controller, and everything was fine, till I needed to make improvements on my setup.
Surprise composer.openremote.org is gone, and can’t access or consult my old design. Grrrrr.
No migration possible, fair enough, I decided to redo everything with the new designer and controller.
One of my command is a shell script I execute to shutdown several PCs on the same network in a single press of a button.
Magic! well… it used to be magic.
It’s not working anymore.
The Wake-On-Lan is working though.
I just wonder what I am doing wrong.
The controller is installed and run on a raspberry Pi 2 running on raspbian Stretch.
Is OpenRemote running fine on this distribution of Raspbian? Cause I changed that, It used to run Raspbian Jessie.
For a simple execution of a script not requiring parameters, only the path is needed for what I remember.
Is it correct?
Thanks in advance for your help
