kmnam
1
Hi.
I set up and ran the simulator as follows, but it doesn’t work.
I would appreciate it if you could let me know the solution.
file:///home/evex/Pictures/%EC%8A%A4%ED%81%AC%EB%A6%B0%EC%83%B7/%EC%8A%A4%ED%81%AC%EB%A6%B0%EC%83%B7%202024-11-07%2013-32-25.png
Sorry, can you try to reupload the image?
kmnam
3
Oh, sorry
I’m reupload the image.
Additionally, the simulator module worked, but it worked at 8 a.m. instead of the time I set, is it impossible to set it to work as soon as it is set?
Don
4
I guess the server time is at 8 hours difference? See the documentation here: Simulator | OpenRemote Documentation
Note that the time is in seconds.
Kind regards,
Don
Pierre
5
kmnam
6
If so, is there a way to adjust the server time? I look forward to hearing from you.
I know you can adjust the TZ environment variable for adjusting the server timezone.
No clue whether this could fix your issue.
@Rich any idea on this issue?
system
Closed
8
