Sorry if the question may seem to be quite trivial but I am a completely new at this (but very eager to learn!!)
I have followed the tutorial on how to connect a MQTT client and I have managed to write attributes using format that were numerical, text and JSON (see figure attached)
Now I have two questions. The first one is less relevant but I basically cannot enable the subscribe attribute.
I have tried to enable it using different methods that I have found online. I am not sure if I am using the wrong topic or the wrong command. These are the topic template that I have tried:
TOPIC: realm_name/mqttclientid/attribute/attribute/deviceid (given in the GitHub wiki)
realm_name/mqttclientid/attributevalue/attribute/deviceid (I have found this online)
CMD: âtrueâ to try to enable the subscribe attribute but also 1 was tried and nothing has been working.
I get an error message âDisconnected from serverâ
I thought that the subscribe attribute needed to be on for me to be able to send in message but even when disabled I am still managing to send in messages to the other attributes so I assume that it is not needed�
(in this case I manually enabled it)
I am using MQTT Explorer to send in commands (not sure if it is relevant).
Let me know if anything is unclear or if it needs additional information.
