does anyone know of a way to create a text input box on the UI that user can input value in and then press a button so that value get assigned to a sensor? for example setting the value for a timer through the UI using a text input
Hi just checking to see if anyone has implemented this?
I've not heard any noises about this.
However...
If you're handy with web page programming, you could create a web page that has a text entry that writes the text to a file that could be polled by an OpenRemote command line command / sensor?
Then just use a web element to display the web page you've created.
