I want to bring lights on when sunset and turn them off at sunrise.
How would one do that?
I have created this
rule “Turn garden lights on” when
Event( source == “Sunset”, value == “true” )
then
execute.command( “Tuinhuis Buiten ON” );
execute.command( “Achterdeur Light ON” );
end
rule “Turn garden lights off” when
Event( source == “Sunset”, value == “false” )
then
execute.command( “Tuinhuis Buiten OFF” );
execute.command( “Achterdeur Light OFF” );
Here is what I use for two switches on the outside of my house:
The Sensor and isNight command is a part of the datetime device.
/* ----------------------------------------------- OUTDOOR LIGHTS ----------------------------------------------- */
rule “Turn Outside Lights on at Sunset”
when
Event( source == “isNightSensor”, value == “true” )
then
execute.command( “Node 10 (ON)” );
execute.command( “Node 14 (ON)” );
end
rule “Turn Outside Lights off at Sunrise”
when
Event( source == “isNightSensor”, value == “false” )
then
execute.command( “Node 10 (OFF)” );
execute.command( “Node 14 (OFF)” );
end
got it.
Thanks you
