This thread was for the old OpenRemote 2.5 controller which is now obsolete.
Running the latest manager on an ARM based device is supported, you need something with a reasonable CPU (64bit) and ideally 2G RAM.
You need to make sure you have a java version with JIT compiler both OpenJDK and Oracle JREs offer this for arm 64bit.
Once you have this and have docker engine installed you can deploy the stack the same way as on a PC.
