I see you’re doing it really thoroughly.
I have the following setup:
OpenRemote-Controller-2.6-beta3
or-zwave-3.4.0-Beta3.jar
Aeotec Z-Stick Gen5 ZW090-C
Danalock V3, Firmware 0.14.6
Just another idea:
1.) Remove Danalock from network
2.) Remove batteries from Danalock and wait a while
3.) Insert batteries
3.) Add Danalock in secure mode
I’ll also test it with the Aeotec Z-Stick S2
Also tried the maneuver to remove/reinsert batteries with same result.
We have exactly the same setup:
- OpenRemote-Controller-2.6-beta3
- or-zwave-3.4.0-Beta3.jar
- Aeotec Z-Stick S2 (that you also verified, my one has firmware 2.78)
- Danalock V3, Firmware 0.14.6
I also have the updated “xercesImpl-2.7.1.jar” file you provided me installed.
My Java version jdk1.8.0_66 if that matters…
You don’t have any other updated files in your OpenRemote installation?
/Nils
Hi Rainer,
For your information, did some additional testing with the Danalock inclusion.
For some reason I tried to go back to use the fileversion “xercesImpl-2.6.2.jar” instead of the 2.7.1 version I got from you earlier and after that tried another secure inclusion of the Danalock. Suddenly it was included securely…
Don’t know if that change really was the thing doing the trick or if it was blind luck. Will not do any more tests now when I finally got the lock included correctly.
However, lock is working great now and is operating as expected. Thanks for all your effort in this matter.
/Nils
