Kindly suggest me how i can add new realm , pls refer screenshot
Seems like some error within the Manager UI.
Can you share the logs of your browsers’ console? (developer tools)
thanks , Issue resolve .
Create new realm from keycloak , but there some issue i can’t create user from new realm .
The process of requesting roles seems to fail.
I looked at our code and it should be showing a different error if no roles exist.
Are there roles present within Keycloak?
And how do you mean: “I can’t create user from new realm”, does the button in the screenshot not work?
hello ,
“I can’t create user from new realm” - actualy after confirmation (user is created successfully ) , its not showing under the same realm .
“Are there roles present within Keycloak?” - pls refer scrrenshot
There was a bug in the realms UI which was fixed in a recent image, please ensure you have the latest manager image.
You can’t create the realm manually without manually creating the required openremote client and roles also; this is taken care of automatically when using the manager to create the realm for you.
