Good Evening,
After giving lot of time and effort still getting same error, please if you can help to understand on what is going wrong here.
Thanks!!
Regards,
Sandeep Mishra
Good Evening,
Thanks!!
Regards,
Sandeep Mishra
Hi sandeep,
What exactly you want to implement ??
Kindly brief and give yml configuration
Hello Apurba,
I am trying to publish raspberry pi cpu temperature under picputemp attribute. I’m using paho mqtt client running on raspberry pi to get this data publish on OR from my pi board.
yml file as below,
version: ‘2.4’
proxy-data:
temp-data:
postgresql-data:
services:
proxy:
image: openremote/proxy:develop
restart: always
depends_on:
manager:
condition: service_healthy
ports:
- "8880:8880"
- "${OR_SSL_PORT:-443}:443"
- "8883:8883"
- proxy-data:/deployment
LE_EMAIL: ${OR_EMAIL_ADMIN:-}
postgresql:
restart: always
# image: openremote/postgresql:latest
- temp-data:/tmp
keycloak:
restart: always
# image: openremote/keycloak:develop
depends_on:
postgresql:
- ./deployment:/deployment
KC_HOSTNAME_PORT: ${OR_SSL_PORT:–1}
manager:
restart: always
# image: openremote/manager:${MANAGER_VERSION:-latest}
# image: openremote/manager-custom:0.2
image: openremote/manager:memory
depends_on:
keycloak:
OR_SETUP_TYPE:
OR_ADMIN_PASSWORD:
OR_SETUP_RUN_ON_RESTART:
OR_EMAIL_HOST:
OR_EMAIL_USER:
OR_EMAIL_PASSWORD:
OR_EMAIL_X_HEADERS:
OR_EMAIL_FROM:
OR_EMAIL_ADMIN:
OR_FORECAST_SOLAR_API_KEY:
OR_OPEN_WEATHER_API_APP_ID:
- temp-data:/tmp
Hi Sandeep,
Quick check: the username of your service user in OpenRemote is also gateway-6hxnauq2bzhhikwbsk9py1?
Don
Hi Don,
Yes correct, service user in OpenRemote is also gateway-6hxnauq2bzhhikwbsk9py1
moreover on checking logs, it seems sometime it authorizes and sometimes it doesn’t,
Thanks!!
Sandeep
there is a password in service user
with secret password configure mqtt client
and r u from india?
Hi Apurba,
Thanks!! for your response,
mqtt client is already configured with the secret password of the service user, you can see the topic is getting published and yes I’m from India.
Sandeep
Hello Apurba,
Please help to conclude, I’m still getting the same issue.
Thanks!!
Hello Apurba/Don,
Changed MQTT Client_ID to make it unique, but seems it has nothing to do with the issue I’am facing,
observations:
a) 25% data drop rate.
b) unreliable behavior
Either OR has some bug or I’m doing something wrong, was hoping to put it over production but with the above two observations, its seems OR to be not a good choice as if now until the issue gets resolved.
Thanks!!
Can we connect in anydesk tomorrow at 11
Hello Apurba,
Sure we will connect at 11 AM ( hope it’s AM ), I’m in IST please let me know your TZ I’ll catch you up.
Thanks!!
Hello Apurba,
can we connect now ?
Thanks!!
Sandeep
Sorry for delay , i am lil-bit busy
kindly connect at https://meet.google.com/gaf-cwvy-yxs?pli=1 at 3 pm today
HI Apurba,
OK 3 PM today.
Hi Sandy,
could you provide your pi code? I guess there is your problem.
not helpful, please provide your actual code (you can mask the secret)
and there is the problem:
clientID = os.uname()[1]#'gateway-6hxnauq2bzhhiwbsk9pyl'#os.uname()[1]
it must be in your case:
clientID = os.uname()[1]#'raspberrypi_picutemp'#os.uname()[1]
the clientID is not your login, it must be a unique identifier and the topic must match it:
realm/CLIENTID/....
