Hi, after pulling latest manager and proxy containers, I tried to stop and remove the old ones, then restart the docker compose with the new downloaded containers.
But I have some problems in the manager container, that won’t restart:
I used the following commands, with containers already stopped:
~/data/openremote$ docker-compose rm manager
~/data/openremote$ docker-compose rm proxy
~/data/openremote$ docker pull openremote/manager:latest
~/data/openremote$ docker pull openremote/postgresql:latest
~/data/openremote$ docker pull openremote/proxy:latest
Then
~/data/openremote$ docker-compose up manager
openremote_postgresql_1 is up-to-date
openremote_keycloak_1 is up-to-date
Starting openremote_manager_1 ... done
Attaching to openremote_manager_1
manager_1 | Picked up JAVA_TOOL_OPTIONS:
manager_1 | Using logging configuration on classpath: logging.properties
manager_1 | 2022-03-14 11:46:40.438 INFO [main ] org.openremote.container.Container : >>> Starting runtime container...
manager_1 | 2022-03-14 11:46:40.456 INFO [main ] .openremote.manager.syslog.SyslogService : Syslog service enabled
manager_1 | 2022-03-14 11:46:40.461 INFO [main ] .manager.security.ManagerIdentityService : Enabling Keycloak identity provider
manager_1 | 2022-03-14 11:46:40.481 INFO [main ] curity.keycloak.KeycloakIdentityProvider : Keycloak service URL: http://keycloak:8080/auth
manager_1 | 2022-03-14 11:46:40.558 INFO [main ] curity.keycloak.KeycloakIdentityProvider : Keycloak proxy URI set to: http://keycloak:8080/auth
manager_1 | 2022-03-14 11:46:40.610 INFO [main ] curity.keycloak.KeycloakIdentityProvider : Connecting to Keycloak server: http://keycloak:8080/auth
manager_1 | 2022-03-14 11:46:40.737 INFO [main ] curity.keycloak.KeycloakIdentityProvider : Keycloak identity provider available: http://keycloak:8080/auth
manager_1 | 2022-03-14 11:46:40.739 INFO [main ] security.ManagerKeycloakIdentityProvider : Loading KEYCLOAK_GRANT_FILE: /deployment/manager/keycloak.json
manager_1 | 2022-03-14 11:46:40.947 INFO [main ] te.model.util.ValueUtil.MODEL_AND_VALUES : Initialising asset model...
manager_1 | 2022-03-14 11:46:41.107 INFO [main ] org.reflections.Reflections : Reflections took 96 ms to scan 1 urls, producing 66 keys and 248 values
manager_1 | 2022-03-14 11:46:41.224 INFO [main ] org.reflections.Reflections : Reflections took 56 ms to scan 1 urls, producing 127 keys and 367 values
manager_1 | 2022-03-14 11:46:41.804 INFO [main ] curity.keycloak.KeycloakIdentityProvider : Keycloak proxy URI set to: http://keycloak:8080/auth
manager_1 | 2022-03-14 11:46:41.809 INFO [main ] container.persistence.PersistenceService : Preparing persistence service for database: POSTGRES
manager_1 | 2022-03-14 11:46:41.831 INFO [main ] container.persistence.PersistenceService : Opening database connection: jdbc:postgresql://postgresql:5432/openremote?currentSchema=openremote
manager_1 | 2022-03-14 11:46:42.249 INFO [main ] ydb.core.internal.license.VersionPrinter : Flyway Community Edition 8.4.0 by Redgate
manager_1 | 2022-03-14 11:46:42.250 INFO [main ] .internal.database.base.BaseDatabaseType : Database: jdbc:postgresql://postgresql:5432/openremote (PostgreSQL 14.1)
manager_1 | 2022-03-14 11:46:42.347 INFO [main ] ydb.core.internal.license.VersionPrinter : Flyway Community Edition 8.4.0 by Redgate
manager_1 | 2022-03-14 11:46:42.398 INFO [main ] ydb.core.internal.license.VersionPrinter : Flyway Community Edition 8.4.0 by Redgate
manager_1 | 2022-03-14 11:46:42.427 SEVERE [main ] org.openremote.container.Container : >>> Runtime container startup failed
manager_1 | org.flywaydb.core.api.exception.FlywayValidateException: Validate failed: Migrations have failed validation
manager_1 | Migration checksum mismatch for migration version 20191202.01
manager_1 | -> Applied to database : -1932254533
manager_1 | -> Resolved locally : -941130336. Either revert the changes to the migration, or run repair to update the schema history.
manager_1 | Need more flexibility with validation rules? Learn more: https://rd.gt/3AbJUZE
manager_1 | at org.flywaydb.core.Flyway$1.execute(Flyway.java:131)
manager_1 | at org.flywaydb.core.Flyway$1.execute(Flyway.java:124)
manager_1 | at org.flywaydb.core.FlywayExecutor.execute(FlywayExecutor.java:214)
manager_1 | at org.flywaydb.core.Flyway.migrate(Flyway.java:124)
manager_1 | at org.openremote.container.persistence.PersistenceService.prepareSchema(PersistenceService.java:507)
manager_1 | at org.openremote.container.persistence.PersistenceService.init(PersistenceService.java:291)
manager_1 | at org.openremote.container.Container.start(Container.java:164)
manager_1 | at org.openremote.container.Container.startBackground(Container.java:209)
manager_1 | at org.openremote.manager.Main.main(Main.java:31)
openremote_manager_1 exited with code 1
Any suggestion?
