openremote is running fine for me with custom deployment, but just when using a preconfigured mbtiles- file from maptiler. However this file lacks of features I need (buildings for example) and is pretty old when using the free version, that’s why I would like to use my own. I downloaded the map from osm and used tilemaker to create the .mbtiles file. However when I try to use this file openremote_manager_1 won’t start and I get this error message:
2022-01-18 04:07:06.777 INFO [main ] org.openremote.manager.map.MapService : Starting map service with tile data: /deployment/map/mapdata.mbtiles
2022-01-18 04:07:06.852 SEVERE [main ] org.openremote.container.Container : >>> Runtime container startup failed
java.lang.NullPointerException
at org.openremote.manager.map.MapService.start(MapService.java:234)
at org.openremote.container.Container.start(Container.java:168)
at org.openremote.container.Container.startBackground(Container.java:209)
at org.openremote.manager.Main.main(Main.java:31)
Picked up JAVA_TOOL_OPTIONS:
Using logging configuration on classpath: logging.properties
So there seems to be a problem with the file, things I tried already:
- Checked the rights of the file
- Completely removed the containers and started fresh
- Removed all features from the ja-settings.json- file I don’t need
Does anyone know wether there is something special to keep in mind when creating the mbtiles- file for openremote? Or how I can get further details, the error message above is pretty meaningless.
Thanks!
