Anybody using Coudflare Tunnels to access his Openremote localhost installation?
I was trying, but still not able to set up correctly - not able to access the login.
I’ve done almost what you are trying to do here; but my use case is exclusively for connecting devices to the various APIs, mostly to the MQTT broker, and I used a VPN tunnel, not CloudFlare tunnels, which is (almost) the same.
How exactly are you running the manager? If you are running it in your IDE, I recommend you use dev-testing, not dev-proxy, because the reverse proxy causes some issues when using a remote IP. With the manager’s ports directly exposed, you can then try out connecting to the manager via HTTP, but I’m honestly not sure how keycloak would react to an HTTP connection from an unknown host.
