I have the same problem. Today I added a new switch plus dimmer to OR2.5 and the switch button only displays the ON graphic. Pressing it sends only the off command. The dimmer/slider works properly. Once on via the Slider, the switch does indeed turn off the device. However, the slider does not move to zero and the switch graphic continues to show the ON image.
The switch is not toggling, repeated presses shows in zwave.log (because my device is a zwave device) that only
/code
DEBUG 2016-07-31 11:13:55,510 (Z-Wave): Command_Builder : Building Z-Wave command
DEBUG 2016-07-31 11:13:55,511 (Z-Wave): Command_Builder : Z-Wave command: nodeId = ‘44’, endPoint = ‘1’
DEBUG 2016-07-31 11:13:55,511 (Z-Wave): Command_Builder : Z-Wave command: command = off
DEBUG 2016-07-31 11:13:55,511 (Z-Wave): Command_Builder : Z-Wave command: paramValue = null
DEBUG 2016-07-31 11:13:55,511 (Z-Wave): Command_Builder : Z-Wave command created successfully
DEBUG 2016-07-31 11:13:55,511 (Z-Wave): CCMultiLevelSwitch : Node ‘44:0’ : [COMMAND_CLASS_SWITCH_MULTILEVEL::SWITCH_MULTILEVEL_SET, Value=‘0’]
DEBUG 2016-07-31 11:13:55,511 (Z-Wave): Controller_API : Enqueue (queue count=1) Z-Wave function call ‘ZW_SendData(NodeID=44, Payload=[0x26, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’.
DEBUG 2016-07-31 11:13:55,511 (Z-Wave): Controller_API : Dequeue (queue count=0) Z-Wave function call ‘ZW_SendData(NodeID=44, Payload=[0x26, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’.
DEBUG 2016-07-31 11:13:55,511 (Z-Wave): TX_Session_Layer : Executing Z-Wave function call ‘ZW_SendData(NodeID=44, Payload=[0x26, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’…
DEBUG 2016-07-31 11:13:55,511 (Z-Wave): TX_Session_Layer : Send (repeat count=1) Z-Wave function ‘ZW_SendData(NodeID=44, Payload=[0x26, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x45)’ request (callback ID=0x45).
DEBUG 2016-07-31 11:13:55,511 (Z-Wave): TX_Frame_Layer : Send data frame [0x01, 0x0A, 0x00, 0x13, 0x2C, 0x03, 0x26, 0x01, 0x00, 0x05, 0x45, 0xAE].
DEBUG 2016-07-31 11:13:55,514 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x06]
DEBUG 2016-07-31 11:13:55,514 (Z-Wave): RX_Frame_Layer : ACK -> Data frame [0x01, 0x0A, 0x00, 0x13, 0x2C, 0x03, 0x26, 0x01, 0x00, 0x05, 0x45, 0xAE] transmission OK.
DEBUG 2016-07-31 11:13:55,514 (Z-Wave): RX_Session_Layer : ACK -> Z-Wave function ‘ZW_SendData(NodeID=44, Payload=[0x26, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x45)’ has been successfully sent - waiting 5,000 [ms] for response frame.
DEBUG 2016-07-31 11:13:55,519 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-07-31 11:13:55,519 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x04, 0x01, 0x13, 0x01]
DEBUG 2016-07-31 11:13:55,520 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0xE8]
DEBUG 2016-07-31 11:13:55,520 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] has been received.
DEBUG 2016-07-31 11:13:55,520 (Z-Wave): RX_Session_Layer : ‘ZW_SendData’ response [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] with status ‘RETURN_VALUE_TRUE’ received (callback ID=0x45).
DEBUG 2016-07-31 11:13:55,520 (Z-Wave): RX_Session_Layer : Waiting 64,992 [ms] for ‘ZW_SendData’ callback frame (callback ID=0x45).
DEBUG 2016-07-31 11:13:55,537 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-07-31 11:13:55,537 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x07, 0x00, 0x13, 0x45, 0x00, 0x00, 0x02]
DEBUG 2016-07-31 11:13:55,538 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0xAC]
DEBUG 2016-07-31 11:13:55,538 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x07, 0x00, 0x13, 0x45, 0x00, 0x00, 0x02, 0xAC] has been received.
DEBUG 2016-07-31 11:13:55,538 (Z-Wave): RX_Session_Layer : Callback [0x01, 0x07, 0x00, 0x13, 0x45, 0x00, 0x00, 0x02, 0xAC] (callback ID=0x45) with state ‘TRANSMIT_COMPLETE_OK’ received -> Z-Wave function ‘ZW_SendData(NodeID=44, Payload=[0x26, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x45)’ successfully executed.
DEBUG 2016-07-31 11:13:55,538 (Z-Wave): CCMultiLevelSwitch : Node ‘44:0’ : [COMMAND_CLASS_SWITCH_MULTILEVEL::SWITCH_MULTILEVEL_SET, Value=‘0’] succeeded
DEBUG 2016-07-31 11:14:02,908 (Z-Wave): Command_Builder : Building Z-Wave command
DEBUG 2016-07-31 11:14:02,908 (Z-Wave): Command_Builder : Z-Wave command: nodeId = ‘44’, endPoint = ‘1’
DEBUG 2016-07-31 11:14:02,908 (Z-Wave): Command_Builder : Z-Wave command: command = off
DEBUG 2016-07-31 11:14:02,908 (Z-Wave): Command_Builder : Z-Wave command: paramValue = null
DEBUG 2016-07-31 11:14:02,908 (Z-Wave): Command_Builder : Z-Wave command created successfully
DEBUG 2016-07-31 11:14:02,909 (Z-Wave): CCMultiLevelSwitch : Node ‘44:0’ : [COMMAND_CLASS_SWITCH_MULTILEVEL::SWITCH_MULTILEVEL_SET, Value=‘0’]
DEBUG 2016-07-31 11:14:02,909 (Z-Wave): Controller_API : Enqueue (queue count=1) Z-Wave function call ‘ZW_SendData(NodeID=44, Payload=[0x26, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’.
DEBUG 2016-07-31 11:14:02,909 (Z-Wave): Controller_API : Dequeue (queue count=0) Z-Wave function call ‘ZW_SendData(NodeID=44, Payload=[0x26, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’.
DEBUG 2016-07-31 11:14:02,909 (Z-Wave): TX_Session_Layer : Executing Z-Wave function call ‘ZW_SendData(NodeID=44, Payload=[0x26, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x00)’…
DEBUG 2016-07-31 11:14:02,909 (Z-Wave): TX_Session_Layer : Send (repeat count=1) Z-Wave function ‘ZW_SendData(NodeID=44, Payload=[0x26, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x46)’ request (callback ID=0x46).
DEBUG 2016-07-31 11:14:02,909 (Z-Wave): TX_Frame_Layer : Send data frame [0x01, 0x0A, 0x00, 0x13, 0x2C, 0x03, 0x26, 0x01, 0x00, 0x05, 0x46, 0xAD].
DEBUG 2016-07-31 11:14:02,912 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x06]
DEBUG 2016-07-31 11:14:02,912 (Z-Wave): RX_Frame_Layer : ACK -> Data frame [0x01, 0x0A, 0x00, 0x13, 0x2C, 0x03, 0x26, 0x01, 0x00, 0x05, 0x46, 0xAD] transmission OK.
DEBUG 2016-07-31 11:14:02,912 (Z-Wave): RX_Session_Layer : ACK -> Z-Wave function ‘ZW_SendData(NodeID=44, Payload=[0x26, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x46)’ has been successfully sent - waiting 5,000 [ms] for response frame.
DEBUG 2016-07-31 11:14:02,917 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-07-31 11:14:02,917 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x04, 0x01]
DEBUG 2016-07-31 11:14:02,918 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x13]
DEBUG 2016-07-31 11:14:02,918 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01, 0xE8]
DEBUG 2016-07-31 11:14:02,918 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] has been received.
DEBUG 2016-07-31 11:14:02,918 (Z-Wave): RX_Session_Layer : ‘ZW_SendData’ response [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] with status ‘RETURN_VALUE_TRUE’ received (callback ID=0x46).
DEBUG 2016-07-31 11:14:02,918 (Z-Wave): RX_Session_Layer : Waiting 64,992 [ms] for ‘ZW_SendData’ callback frame (callback ID=0x46).
DEBUG 2016-07-31 11:14:02,935 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2016-07-31 11:14:02,935 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x07, 0x00, 0x13, 0x46, 0x00, 0x00, 0x02]
DEBUG 2016-07-31 11:14:02,936 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0xAF]
DEBUG 2016-07-31 11:14:02,936 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x07, 0x00, 0x13, 0x46, 0x00, 0x00, 0x02, 0xAF] has been received.
DEBUG 2016-07-31 11:14:02,936 (Z-Wave): RX_Session_Layer : Callback [0x01, 0x07, 0x00, 0x13, 0x46, 0x00, 0x00, 0x02, 0xAF] (callback ID=0x46) with state ‘TRANSMIT_COMPLETE_OK’ received -> Z-Wave function ‘ZW_SendData(NodeID=44, Payload=[0x26, 0x01, 0x00], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x46)’ successfully executed.
DEBUG 2016-07-31 11:14:02,937 (Z-Wave): CCMultiLevelSwitch : Node ‘44:0’ : [COMMAND_CLASS_SWITCH_MULTILEVEL::SWITCH_MULTILEVEL_SET, Value=‘0’] succeeded
^C
/code
