Hai
i facing the problem with open remote azure cloud installation We are sorry…
Invalid parameter: redirect_uri
In a desktop environment, you are likely using localhost. For the stack operating on a public cloud, a proper DNS configuration is required. Could you please provide your current DNS settings?
thank you very much to reply. i am a new for this type of works. i configure any dns not yet but i install open remote in azure cloud vm with docker compose.my public ip 20.197.50.216 I also install wemin in that same vm to moitor and configure the vm.
(https://20.197.50.216:10000/)This is the webmin url.can you please tell me how to configure dns.
Dear,
DOMAINNAME: localhost ,
change this line to below line (proxy image , keycloak , manager ) in yml file
DOMAINNAME: 20.197.50.216 and browse your IP in browser
Thankyou verymuch to repy
I modify as per your suggesion. thare no change at all please find the attachment of text of yml file.
docker-compose .txt (2.5 KB)
20.197.50.216 is a bare IP address, and it is not possible to obtain a certificate for it. You will need a DNS name, likely assigned automatically by Azure. Please use that DNS name instead.
thanking you very much to reply sir.
