Openremote works fine on my lan. I tried to do port forwarding on my router to access the server externally.
But it’s not working. I don’t have much knowledge about HAProxy, I suspect it is related. Could someone explain it to me?
Do you have static IP?
you need to forward 3 port 80 ,443 , 8883 on your router
Hello Apurba, i don’t have static ip. I’m using a ddns called duckdns.
I tested the port forwardins with others applications listening on this ports, but the error is only with openremote.
80, 443, and 8883 were forwarded.
My docker-compose.yml file is presented below:
# OpenRemote v3
version: '2.4'
proxy-data:
manager-data:
postgresql-data:
services:
proxy:
restart: always
depends_on:
manager:
condition: service_healthy
ports:
- "80:80" # Needed for SSL generation using letsencrypt
- "${OR_SSL_PORT:-443}:443"
- "8883:8883"
- "127.0.0.1:8404:8404" # Localhost metrics access
- proxy-data:/deployment
LE_EMAIL: ${OR_EMAIL_ADMIN:-}
DOMAINNAME: 192.168.0.129
postgresql:
restart: always
shm_size: 128mb
ports:
- "5432:5432"
- manager-data:/storage
keycloak:
restart: always
depends_on:
postgresql:
- ./deployment:/deployment
KC_HOSTNAME: 192.168.0.129
manager:
# privileged: true
restart: always
depends_on:
keycloak:
ports:
- "127.0.0.1:8405:8405" # Localhost metrics access
OR_SETUP_TYPE:
OR_ADMIN_PASSWORD:
OR_SETUP_RUN_ON_RESTART:
OR_EMAIL_HOST: smtp.mailersend.net
OR_EMAIL_USER: XXXXXXXXXXXXXXXXXXXX
OR_EMAIL_PASSWORD: XXXXXXXXXXXXXXXX
OR_EMAIL_X_HEADERS:
OR_EMAIL_FROM: XXXXXXXXXXXXXXXX
OR_EMAIL_ADMIN: XXXXXXXXXXXXXXXX
OR_HOSTNAME: 192.168.0.129
OR_SSL_PORT: 443
OR_ROOT_REDIRECT_PATH: /manager/?realm=user
OR_FORECAST_SOLAR_API_KEY:
OR_OPEN_WEATHER_API_APP_ID:
# - manager-data:/storage
HI,
post the error here .
I think you should try to this ,To access your OpenRemote server externally, proper port forwarding on your router is essential. Ensure that you have forwarded the correct ports to the internal IP address of your OpenRemote server. HAProxy is a load balancer and proxy server that can manage and direct traffic to your server. If HAProxy is part of your setup, it might need configuration adjustments to handle external traffic correctly. Make sure HAProxy is configured to listen on the correct external ports and forward that traffic to your OpenRemote server. I hope you understand or satisfied.
