I am using the latest docker image. However, I have problem starting the Z-Wave agent. After adding the agent and configure the port, the Z-Wave agent simply won’t run.
The log says it is started:
2023-12-06 19:05:07.742 FINE [Scheduled task-9 ] rg.openremote.manager.agent.AgentService : Starting protocol instance: Z-Wave[]
2023-12-06 19:05:07.751 FINE [Pool-PersistenceTopic-52 ] remote.manager.asset.AssetStorageService : Asset query took 11ms: return count=1
2023-12-06 19:05:07.753 FINE [Pool-PersistenceTopic-52 ] remote.manager.asset.AssetStorageService : Asset created: ZWaveAgent{id='78pqpHJl6rjRTK8gxN4CmZ', name='ZW1', type ='ZWaveAgent', parentId='null', realm='master'}
But after that, there is no activity at all. Assets discovery will return error:
2023-12-06 19:12:35.258 FINE [WebService task-3 ] enremote.container.web.RequestLogger.API : Client request 'GET /agent/assetDiscovery/78pqpHJl6rjRTK8gxN4CmZ (responseType=application/json, text/plain, */*)', requestRealm=master, username=master:admin, origin=172.19.0.5:51140, forwarded-for=192.168.178.108
2023-12-06 19:12:35.266 FINE [WebService task-3 ] emote.container.web.WebServiceExceptions : Web service exception in 'RESTEasy Dispatch' for 'GET http://192.168.178.81/agent/assetDiscovery/78pqpHJl6rjRTK8gxN4CmZ' type = UnsupportedOperationException, message=Agent is either invalid, disabled or mis-configured: ZWaveAgent{id='78pqpHJl6rjRTK8gxN4CmZ', name='ZW1', type ='ZWaveAgent', parentId='null', realm='master'}
java.lang.UnsupportedOperationException: Agent is either invalid, disabled or mis-configured: ZWaveAgent{id='78pqpHJl6rjRTK8gxN4CmZ', name='ZW1', type ='ZWaveAgent', parentId='null', realm='master'}
at org.openremote.manager.agent.AgentService.doProtocolAssetDiscovery(AgentService.java:695)
at org.openremote.manager.agent.AgentResourceImpl.doProtocolAssetDiscovery(AgentResourceImpl.java:128)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:170)
at org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:130)
at org.jboss.resteasy.core.ResourceMethodInvoker.internalInvokeOnTarget(ResourceMethodInvoker.java:660)
at org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTargetAfterFilter(ResourceMethodInvoker.java:524)
at org.jboss.resteasy.core.ResourceMethodInvoker.lambda$invokeOnTarget$2(ResourceMethodInvoker.java:474)
at org.jboss.resteasy.core.interception.jaxrs.PreMatchContainerRequestContext.filter(PreMatchContainerRequestContext.java:370)
at org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTarget(ResourceMethodInvoker.java:476)
at org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:434)
at org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:408)
at org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:69)
at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:492)
at org.jboss.resteasy.core.SynchronousDispatcher.lambda$invoke$4(SynchronousDispatcher.java:261)
at org.jboss.resteasy.core.SynchronousDispatcher.lambda$preprocess$0(SynchronousDispatcher.java:161)
at org.jboss.resteasy.core.SynchronousDispatcher.preprocess(SynchronousDispatcher.java:164)
at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:247)
at org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.service(ServletContainerDispatcher.java:249)
at org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:60)
at org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:55)
at jakarta.servlet.http.HttpServlet.service(HttpServlet.java:614)
at io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:74)
at io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:129)
at org.openremote.container.security.CORSFilter.doFilter(CORSFilter.java:87)
at org.openremote.container.web.file.HttpFilter.doFilter(HttpFilter.java:108)
at io.undertow.servlet.core.ManagedFilter.doFilter(ManagedFilter.java:67)
at io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:131)
at io.undertow.servlet.handlers.FilterHandler.handleRequest(FilterHandler.java:84)
at io.undertow.servlet.handlers.security.ServletSecurityRoleHandler.handleRequest(ServletSecurityRoleHandler.java:62)
at io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:68)
at io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36)
at org.keycloak.adapters.undertow.UndertowAuthenticatedActionsHandler.handleRequest(UndertowAuthenticatedActionsHandler.java:66)
at io.undertow.servlet.handlers.RedirectDirHandler.handleRequest(RedirectDirHandler.java:68)
at io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:117)
at io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57)
at io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43)
at io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46)
at io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64)
at io.undertow.security.handlers.AuthenticationMechanismsHandler.handleRequest(AuthenticationMechanismsHandler.java:60)
at io.undertow.servlet.handlers.security.CachedAuthenticatedSessionHandler.handleRequest(CachedAuthenticatedSessionHandler.java:77)
at io.undertow.security.handlers.AbstractSecurityContextAssociationHandler.handleRequest(AbstractSecurityContextAssociationHandler.java:43)
at org.keycloak.adapters.undertow.ServletPreAuthActionsHandler.handleRequest(ServletPreAuthActionsHandler.java:72)
at io.undertow.servlet.handlers.SendErrorPageHandler.handleRequest(SendErrorPageHandler.java:52)
at io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:276)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:135)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:132)
at io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:48)
at io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
at io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:256)
at io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:101)
at io.undertow.server.Connectors.executeRootHandler(Connectors.java:393)
at io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:859)
at org.jboss.threads.ContextHandler$1.runWith(ContextHandler.java:18)
at org.jboss.threads.EnhancedQueueExecutor$Task.run(EnhancedQueueExecutor.java:2513)
at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.run(EnhancedQueueExecutor.java:1538)
at org.xnio.XnioWorker$WorkerThreadFactory$1$1.run(XnioWorker.java:1282)
at java.base/java.lang.Thread.run(Thread.java:840)
